Realtek High Definition Audio Troubles - Not Detecting Anything
Page 2 of 2 FirstFirst 12
  1. Posts : 4,161
    Windows 7 Pro-x64
    Why did you go back to an old BIOS?
    Right click the speaker in the lower right then select Sounds. Click on the Playback tab then right click on Speakers. Click on Properties. At the bottom of the Properties window, see if the speakers are enabled. (Use this device)
  2. Posts : 11
       #12
    It's enabled.
    ~FX
  3. Posts : 11
    Any help please ?
    Thank you!
    ~FX
  4. Posts : 11
       #14
    Took the graphics card out, no difference.
    Used HDMI, sound came out the TV's speakers.
    ~FX
  5. Posts : 4,161
    Windows 7 Pro-x64
       #15
    Try unplugging the speakers then make sure the plugs go all the way in.
  6. Posts : 11
       #16
    Speakers, and or Headphones are all the way plugged in.
    So is the Mic.
    ~FX
  7. Posts : 4,161
    Windows 7 Pro-x64
       #17
    Did you unplug them and re-insert?
  8. Posts : 87
    Windows 7 Ultimate 32bit
       #18
    di you get the drivers from...... A780L3G :: Motherboard :: BIOSTAR
    on board audio drivers...
  9. Posts : 11
       #19
    Ran it (Admin)
    Did nothing different, the playback devices is still the same as the one in the OP.
    I've done all the obvious (Unplug, replug, etc.)
    ~FX
