Static problem
  1. Posts : 3
    Windows 7 32bits
    Static problem
    Hello everybody.
    I have recently installed Windows 7 in my laptop and I've encountered a really annoying problem that I can't seem to solve: static sound.
    I have a Realtek HD Audio with the latest updates (R2.66), tried to install older updates like Vista ones but still the same static. Although, if I set to use High Definition Audio Device controllers (Windows ones), the static gets soften but still there.
    Any idea of how to solve this problem? =\
  2. Posts : 7
    1. Laptop or Desktop?
    2. Is the static present in headphones and in speakers?
    3. Are you using an amplifier?
  3. Posts : 3
    Windows 7 32bits
    Hey ssaamm.
    As I said, it's a laptop.
    Yes, even with headphones the static remains.
    No, i'm not using and amplifier.
  4. Posts : 644
    Windows 7 home premium x64
    Do have a mic plugged in or do you use one at all ? it may help to disable realteks mic input via their control thingy.
  5. Posts : 3
    Windows 7 32bits
    The microphone is incorporated on the laptop and I already disabled it on realtek "console"
