Creative sound card, windows 7 compatible volume control?
  1. Posts : 1
    I recently bought a dell computer second-hand from my friend, who had XP installed on it. It came with a subwoofer and a set of 4 regular speakers. On it, he had installed a form of creative volume control in addition to windows volume. The way it worked was he had the windows volume set to 100% at all times, and the creative volume control around 3% for regular browsing, 10-25% for gaming and 50% or higher for rocking out with music. I recently acquired windows 7 home premium x64 and upgraded my operating system. My soundblaster card has all the necessary drivers and the audio is all hooked up properly, and the only thing missing is this form of volume control. After looking around for the old software and trying a few different freeware and shareware programs, nothing has pulled through for me; any suggestions?
  2. Posts : 109
    Windows 7 Ultimate SP1 x64
    What exact sound card do you have?
    Have you checked creative's website for additional software that goes along with the driver of your card? Is the windows volume not sufficient for you, or do you just want the extra ability for volume control?
    If you installed the creative driver, have you checked in the audio control panel that's built into the driver?
