Sound Card recommendations
  1. Posts : 795
    10 Home x64
    I have some money to spare on my gaming rig, and I thought the next thing to upgrade would be the sound card. Right now, I'm using the integrated 7.1 audio on my Asus motherboard, which isn't anything special.
    I'm using a true 5.1 headset (Roccat Kave).
    I was thinking of purchasing a Creative Soundblaster X-Fi Titanium Fatal1ty Professional. Would this make much of a difference, and or do you recommend better at a similar price?
  2. Posts : 5,405
    Windows 7 Ultimate 64bit SP1
    Hi.
    Is this your motherboard?
    ASUSTeK Computer Inc. - Motherboards- ASUS M4A89GTD PRO/USB3
    ""ALC 892 8-Channel High Definition Audio CODEC
    - BD Audio Layer Content Protection
    - Support 192khz/24bit True BD Lossless Sound
    - DTS Surround Sensation UltraPC
    - Supports Jack-Detection, Multi-Streaming, and Front Panel Jack-Retasking
    - Optical S/PDIF Out ports at back I/O
    - ASUS Noise Filter""
    And you want more?
    I know that,you didnt ask this but....
    If you want to spend some money buy SSD to boost your system.
    SSD = faster computer,windows,loading,gaming,......
  3. Posts : 12,012
    I doubt it would make an improvement. You might hear a "difference", but who knows if you think that would be an improvement.
    I'd avoid Creative Labs except at the point of a gun.
    If you want to upgrade sound, look at your other hardware: speakers, amplifier, headphones.
    Or better yet, spend the money elsewhere--like on an SSD.
  4. Posts : 5,405
    panais said:
    Hi.
    And you want more?
    ignatzatsonic Its seem that we agree!
  5. Posts : 795
    10 Home x64
    panais said:
    Hi. Is this your motherboard?
    Yes, that is. I didn't know it had such good integrated sound
    I would spend the money on an SSD, but 1 I want high capacity and 2 Wouldn't that mean I'd have to reinstall Windows and everything? I have a system image on my other hard drive if that makes a difference...
    Also as of right now the prices of Hard Drives are too high.
  6. Posts : 12,012
    MadSupra354 said:
    I would spend the money on an SSD, but 1 I want high capacity (around 300GB) and 2 Wouldn't that mean I'd have to reinstall Windows and everything? I have a system image on my other hard drive if that makes a difference...
    The standard way to use SSDs is to just use them for Windows and your installed applications----that is normally no more than 100 GB, usually less.
    Then use your regular hard drive for all of your data.
    You should be able to restore your image to a new SSD. Even if you had to reinstall Windows, I'd say an SSD is a better way to spend on an upgrade than to buy a new sound card.
    The prices of SSDs have not moved much. Regular hard drives have jumped way up.
  7. Posts : 795
    10 Home x64
    I don't really see the point in using an SSD just for Windows. Especially with Windows 8 improving boot times drastically.
  8. Posts : 12,012
    Ideally, you'd like everything on an SSD.
    You will have a long wait if you are waiting for SSDs of, say, 1TB, to be priced anywhere near what a comparable HDD would be---years.
  9. Posts : 5,405
    Just a few benefits from SSD Top Ten Benefits of SSD | Samsung Business Insights and more....better\faster gaming,in loading and in gaming.........amd more....
    The above is from Samsung,though they are even faster SSD like OCZ vertex etc.
