Sigmatel 97XX C-Major Audio Driver Help Needed!
  1. Posts : 4
    SOLVED: Sigmatel 97XX C-Major Audio Driver Help Needed!
    I have an older P4 2.8ghz Dell Dimension 3100 that currently has Windows 7 installed. Apparently the driver is the Sigmatel 97xx C-Major audio according to support.dell.com - the first thing I tried was the Windows Vista driver listed on Dell's site. Unfortunately that did not work. The driver appears to be installed and I have a sound device however I have no output through the speakers. I'm sure it is a driver related issue.
    The device enabled, the speakers work and are hooked up properly.
    Any ideas where I can find a Windows 7 driver for the Dimension 3100 using the onboard Sigmatel 97XX?
  2. Posts : 682
    Window 7 build 7600, Xp pro(VM)
    Welcome to SF.
    Have you tried downloading it via windows update?
  3. Posts : 4
    septprince said:
    Welcome to SF.
    When using Windows Update it installs something called High Definition Audio Device which still does not work.
  4. Posts : 4
    Well let me just state I think I fixed it...
    I removed all drivers. Ran Windows Update on that driver. It installed the High Definition Audio Device - I went into playback devices and made sure the speakers were enabled and voila! It works - :) Well thanks I guess heh!
  5. Posts : 4
    Well now the only other issue I have is with my Line 6 Guitar Port not working. I should probably make a new thread for that issue.
  6. Posts : 682
    If you problem solved please ask a mod to mark the this thread as solved..
