Downloaded .wav file will not play in sound effects
I'm trying to change some of the various sound effect with downloaded portal .wav files. So have worked while others have not. The only difference I have seen between the one that have worked and the ones that don't is that the working one show a bit rate in their properties. Is there anyone that knows how I can fix this? Thank you very much.
