capture m-audio fast track sound using my notebook
  1. Posts : 2
    windows 7 home premium edition sp 01 (build 7601)
    Greetings !
    my notebook asus n53sv recognizes everything , i install the drivers , i did this process of disable and enable . i put as the main record device , my m-audio fast track to record my guitar . I use pro tools ,audacity and now i am trying on cubase 5 . and is all mute .
    is the version of windows ?
    not compatible ?
    i see the signal coming , but i cant hear and adjust the latency or other options of the fast track .
    anyone can help please ?
    I have a studio using Sonar X1 and I'm considering converting to Pro Tools as I have PT MP9. I also have an MAudio Fastrack Ultra 8R USB connected unit. I can use the Fastrack Ultra 8R with both Sonar and Pro Tools.
    When you are using a recording program you do not need to set any recording device in the Sound Panel. The recording program sets up the device for recording.
    The first thing is to make sure you are installing the MAudio unit correctly. When I installed my MAudio unit, I ran the MAudio installation program, which also installed the MAudio Control Panel for the Fastrack Ultra 8R. I then connected the unit and it was detected and Installed by Windows. Once it is detected and installed correctly you can then use Pro Tools or whatever and set up the audio, in the recording program for your MAudio unit.
    There is also an MAudio forum, for help with MAudio Devices: The Official M-Audio User Forums
  3. Posts : 2
    capture m-audio fast track sound using my notebook part 2
    Greetings Freebird !
    I did step by step , everything by the book .
    The strange part is that the windows recognizes everything , but i dont hear and the programs dont acept . That's why i dont know what to do now .
    the notebook have 2 weeks , is a baby . i didnt install nothing wierd , and almost nothing . I search in many foruns , and nothing totaly in comon i see ,compared to other problems .
  4. Posts : 8,135
    As I stated, if you want to use the MAudio device with your Recording Program, you set it up in the Recording Program. It is NOT for PC sound. The language translation must be losing something somewhere.
