How can I get sound output from sound card when streaming video?
  1. Posts : 56
    window 7 64b SP1
    I get sound from the mic of course.but I would like to get sound straight from the sound card too when I want to.I don't know exact model,but it's a realtek HD on board sound card.Acer 5551 series laptop
  2. Posts : 2,588
    Hello green,
    You get sound from your microphone? I don't think I am understanding. Sound should come from your sound card. You plug the speakers into the back of the computer and into the sound card (green jack). The mic receives sound. My mic is USB so it doesn't use any jack other than the USB port, but if you use the sound card, it goes into the purple jack
    Do you have the audio driver installed? This should be right: http://support.acer.com/product/defa...x?modelId=2192
  3. Posts : 56
    window 7 64b SP1
    Was kinda in a hurry.I meant my mic receives sound in my room.My sound driver is fine.I got a mic built in my laptop,it works fine.What I want to do is get the sound to work directly off the sound card,not just pick the sound up from the mic when I key in on chat etc.
  4. Posts : 2,588
    Ah, I must be daft, but I still am not fully understanding. Do you want the sound card to act as a microphone? Or do you want to use your sound card and connect the mic to it? Or do you want the mic to work without having to "key in"... Details for this one, please. Very specific.
    Um... or do you want to be able to hear from the sound card (to the speakers) what goes into the mic? heh....
  5. Posts : 56
    window 7 64b SP1
    Yes
  6. Posts : 4,161
    Windows 7 Pro-x64
    Please elaborate on what you're trying to accomplish.
  7. Posts : 56
    window 7 64b SP1
    Sorry for the confusion guys.
    I had to go to sound,recording devices,right click,tick show disabled devices,exit,go back to sound,recording devices,right click stero mix & enable it .Learned something new today:)
    Attached Thumbnails Attached Thumbnails How can I get sound output from sound card when streaming video?-sc-mic.png
  8. Posts : 2,588
    Ah, now I getcha. You mean recording pc sounds, yes you found it. I thought somehow you meant ambient sounds that would somehow be picked up by the card o.0
    Absurd, I know. Sorry for getting all confused. Glad you got it sorted
