I can hear sound only from the Monitor speakers
  1. Posts : 17
    win7 home and prof 64bit
    Yes, your both right, I think, it sound very much like a audio driver.
    But I'm a bit confused because windows doesn't report any errors.
    Yes, this is an onboard soundcard (not too bad) on an ASUS P8H67.
    (HD Audio 8 Channel, audio codec Realtek ALC887).
    OK, next I'll try to deinstall and reboot... see what happens.
  2. Posts : 64
    Windows 7 Pro x86; Pro x64; Home Prem x64; and others....
       #12
    Please click Start > type System Information > Enter.
    Under >
    System Summery > Components > Sound Device;
    post a screenshot.
    Attached Thumbnails Attached Thumbnails I can hear sound only from the Monitor speakers-info.jpg
  3. Posts : 17
    @Joodoo,
    I don't know how you managed to put the screenshot int the text area, I just attached the img under attachements.
    Fyi, I deleted all of the audio drivers but it didn't help neither.
    Attached Thumbnails Attached Thumbnails I can hear sound only from the Monitor speakers-sound-device.jpg
  4. Posts : 12
    Window 7 Ultimate x64, Linux
       #14
    Microsoft Device Driver Interface for HD Audio
    This should be the driver you need.
  5. Posts : 17
       #15
    Thanks @rabid moth,
    this is a white paper on programming and a reference for the Intel High Definition Audio device driver interface.
    Unfortunately this couldn't me help finding any missing(?) driver.
  6.   My Computer
  7. Posts : 12
       #17
    I found a PC that I can get my hands on that is having the same issue. Checking different things now.
  8. Posts : 12
       #18
    Here's what I did.
    I first went to this site, Realtek and downloaded the High Definitions Audio Codecs.
    I installed the driver and rebooted. Now when I plug my headphones into her PC I can hear sound. I still don't have a headphone icon though.
  9. Posts : 64
       #19
    This machine is designed for XP Pro. My sound card driver is not supplied on Windows 7 Pro x86 SP1 install media or any other Windows 7 install media. After exaustive searching, the driver had to be extracted from the recovery media supplied by the manufacturer of the computer [talk about proprietary]. I had to run the driver installer .cab under compatibility mode as well as administrator.
    As this seems to be a home built machine, try Rabid Moth's suggestion and see what happens.
    Keeping my fingers croosed.:)
    Please create a system image in case something runs amok.
    Edit: Seems you post images better than I.
    Edit 2:
    I have just plugged in my headphones (Wife doesn't want to hear Gregoy Isaacs - Night Nurse), and had to start Sigmatel (my sound card) from the shortcut I had preparedto in Start Menu to operate the headphones.
    Just sayin'; somethimes it can be a pickle.
    Attached Thumbnails Attached Thumbnails I can hear sound only from the Monitor speakers-stac.jpg
  10. Posts : 17
       #20
    Wow!
    That was the great hint!!!!
    Thank you all so much!
    With the realtek driver I can now configure my audio system in any detail, so I could activate the AC97 Front panel (Headphones/Speaker) and now it works.
    Now I wonder of cource why it stopped working?
    Thanks again especially @Rabid Moth!
    And a happy new year hopefully with less problems:)
