@ignatzatsonic behringer ufo 202 is not available but behringer uca222 is available will that do??
The UFO-202 is available here:
http://www.amazon.com/s/ref=nb_sb_no...nger&x=17&y=14
at Amazon, along with the UCA 222.
I have no knowledge about the UCA 222, but at first glance it looks like it has only 4 connection points, not 5 like on the UF0-202.
I suspect that missing connection point is a ground for a turntable, which you should have if you intend to connect a turntable to it.
Nor do I know if the UCA 222 has built in RIAA equalization, as the UFO 202 does.
All I can suggest is to drill into Behringer.com and google generally to find out what you can.
@ignatzatsonic i managed to acquire a behringer ufo202 and iv hooked it up to my system... my garrard 6200c does not have a separate ground pin.. when i plug in my head phones and turn the volume of the behringer pre amp all the way up theres a huge bass hum .... and my recording software shows me an input present in the form of a square wave... ?? whats the problem??
