Sound problem. Plz help.. images attached..
Page 1 of 5 123 ... LastLast
  1. NRT
    Windows 7 Ultimate 64-bit SP1
    I've upgraded my computer... now a sound problem arises... I'm using bubbles as my screensaver set to 6 mins, after that in power options turn off monitor at 15 mins.. I've installed Adobe Audition, Winamp etc.. when i tried to play a song in winamp, it shows like the below attached image, opened audition: same problem, opened WMP: same problem... no sound from computer... i've checked speaker levels, while moving the slider, it shows nothing... plz help... is it a motherboard problem ???
    Attached Thumbnails Attached Thumbnails Sound problem. Plz help.. images attached..-capture1.png   Sound problem. Plz help.. images attached..-capture2.png   Sound problem. Plz help.. images attached..-capture3.png
  2. NRT
    any help?
  3. Posts : 564
    Windows 8 Pro
    Try to re-install your sound card drivers.Go to device manager and check if there are any yellow exclamation marks on sound devices.
  4. NRT
    no... the device manager has no yellow exclamation marks.. i've re installed the sound drivers... but sound is goin at irregular times...
  5. Posts : 564
    Windows 8 Pro
    Are you using integrated sound card or is it an external one??If its the latter i suggest checking if sound card is seated properly on the MB.Otherwise maybe your sound card is failing.
  6. NRT
    integrated sound card...
  7. Posts : 564
    Windows 8 Pro
    I remember not long ago when i build my desktop for the first time i had ASUS MB and on board sound card failed.If your MB is still under warranty i suggest to take it to ASUS repair center.
    Or hold on others may have better suggestion.
  8. Posts : 9,582
    Windows 8.1 Pro RTM x64
    I've checked the Asus page for your motherboard, and the latest audio driver they have is the following:
    VIA Audio Driver V6.0.1.7900 for Windows 32/64bit XP & 32/64bit Vista 2010.03.26 update
    http://uk.asus.com/Motherboards/AMD_...M_LE/#download
    From the VIA website for the VT1708S audio device: VIA Drivers Download - VIA Technologies, Inc.
  9. NRT
    yes... this driver is i'm now using... but no luck...
  10. NRT
    is it a sound card problem.. ?? or it cud b a virus ?? plz help...
