Sound problem. Plz help.. images attached..
Page 4 of 5 FirstFirst ... 2345 LastLast
  1. NRT
    Windows 7 Ultimate 64-bit SP1
       #31
    Golden said:
    I do not think this behaviour is malware - besides you have already done a clean install which will have removed the malware. This sounds hardware/driver-related.
    Regards,
    Golden
    thank u Colin... appreciated.... hav a great day .... cheers.... :)
    so im gonna change my MB...
  2. Posts : 5,440
       #32
    OK Try this. Open Control Panel, then Hardware and Sound then click the Playback tag. You should have one device that reads "Speakers". Has that got a green tick on it, if not right click on Speakers and choose "Set as Default device"
  3. NRT
       #33
    wer shud i click ?
    Attached Thumbnails Attached Thumbnails Sound problem. Plz help.. images attached..-hardware.png
  4. NRT
       #34
    ya ya... i saw it... it is already the default device....
  5. Posts : 5,440
       #35
    Then make the other devices the default in turn to see if one of them works!
  6. NRT
       #36
    ok....
  7. Posts : 4,049
       #37
    Start and logon sounds?
    Does your PC play the Windows start and logon sounds?
  8. NRT
       #38
    yes...
  9. Posts : 4,049
       #39
    sfc /scannow
    You may need to open the "Command Prompt" and execute:
    sfc /scannow
    Tutorial:
  10. Posts : 8,476
    Windows® 8 Pro (64-bit)
       #40
    After reading 4 pages of this thread, It looks like its an issue with the integrated audio (basically, the motherboard). Instead of replacing the motherboard, just get an external sound card and install it. It would be a cheaper option as well.
    Good Luck,
    Dinesh.
