No sound in stereo
Page 2 of 2 FirstFirst 12
  1. Posts : 5
    win 7
    Ok i figured out the problem, i also changed the case for this pc and it doesn't have front audio ports, so i should have put some jumpers on the board or otherwise the rear line out on the board is cut out.
    Thanks for all the help
  2. Posts : 1
    I spent several hours and digging through many sites and threads and I couldn't find a solution. I have the alc850 and had the same situation as you, everything looked good, win 7 showed the speakers playing sound, but I didn't hear a single thing from the speakers. Your solution did the trick!
    Thanks again! I signed up just to express my thanks - I was cursing Windows 7, but now that I have sound, I'm all
  3. Posts : 9
    Windows7
    [ame="http://www.youtube.com/watch?v=DC1r-EBl4y4"]YouTube - How to fix Sound Bug In Windows 7[/ame] This should work
