My Sound is too loud how do i tone it down a bit?
  1. Posts : 30
    I dont know if this should consider to be a problem but its a little annoyance to me, the sound is too loud even if i turn it down or turn down the application sound (Example: Youtube) is there anyway for me to tone it down a little bit?
  2. Posts : 30
    I am using external speakers sorry for not adding that
  3. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Yes,
    Playback, Speakers, Properties, Levels, Front.
  4. Posts : 30
    Sardonicus said:
    Yes,
    Thank you will try and see results
    Hmm a little confuse on what i need to set any suggestions? I set everything on 50
  5. Posts : 1,996
    You can adjust the output levels.
