How do I change sound mute key in W7 Pro
  1. Posts : 2
    Windows 7 Professional x64
    Hi there,
    At the moment the key to mute sound for me is grave (`)
    Would like to know how to disable / change this key
    Thanks in advance
  2. Posts : 14,606
  3. Posts : 2
    Hey, thanks for the reply
    I believe it was a program causing the before mentioned key to mute my computer as I can't replicate it at the moment
    Will repost later if I find out the source of my problems
