Sound Card upgrade?
I was thinking of upgrading my sound card but my motherboards only PCI x1 slot sits right next to the graphics slot. Having the GTX 470 it uses double the space so the sound card if installed would be right below the vid card. My concern, would the heat from the vid card damage the sound card? It would practically be touching each other. Has anyone run into this? Has it caused you any issues?
