Realtek AC'97 Audio (Code 10)
Page 4 of 5 FirstFirst ... 2345 LastLast
  1. Posts : 2
    Windows XP Pro w/SP3 - Win7
       #31
    Digger said:
    Here is the link for the vista driver R2.14. Dated 2009/1/9
    http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
    I have found this to work with no problem. Also has the 3D SoundBack beta 0.1 (audio effect/enhancement for Vista) not tested by me yet.
    All I could get was the R2.24 drivers for HD and I would get the Code (10) error, I uninstalled, reinstalled, tried all the different drivers here, (the ones that I could get) and to no avail, till the Vynal ones made the code 10 go away, but couldn't hear anything...... I switched back to XP Pro and all was fine in Dewyland again, so I know the onboard sound was fine, and evrything is attached as supposed to be, so I went back to win 7 and yet I am stuck without sound....... I even let it update from Vynal, and to no avail as it went right back to code (10)
  2. Posts : 995
    XP/win7 x86 build 7127
       #32
    yea, i posted this some months back. Now of course they are on version 2.23/24. Never heard of this Vynal you speak of. Also i just did a google search for the 2.14's if you wish to try, they are all over the net. I am still using the 2.14's .... as if it aint broke, dont upgrade, is the motto for me. I havent tried any of the other drivers to give you any feedback on them.
    good luck
    realtek 2.14 drivers - Google Search
  3. Posts : 2
       #33
    Vinyl Misspelled...LOL
    vprimachenko said:
    I has had same problem. Finally, after hours of donwloading and installing, i found a solution. So in my case i installed the VIA Vinyl AC'97 Drivers and all was suddenly ok.
    Thoes are the drivers I speak of, and thankx for your input.... got them but still to no Avail, maybe because the Vinyal isn't HD, and maybe because my onboard card isn't either..... going today to get a new card and see if I can just fix it thata way.....
  4. Posts : 1
    Windows 7 (Laptop) Vista Ultimate 64bit (Desktop)
       #34
    I finally got the AC'97 drivers to work on my Asus Z71V laptop.. They were dated 6/22/09 R2.27. Finally I can enjoy sound while in this OS.
  5. Posts : 1
    Windows 7 ultimate
       #35
    i got it workin
    just go to manufacturers site and download windows 2000 drivers. i got it work on Fujitsu and HP units.
  6. Posts : 1
    XP/Vist/7
       #36
    Very good my friend. I spent a whole day and tried all of these drivers mentioned in this thread and none worked. After I downloaded Windows 2000 drivers from manufacturer website it works perfect.
    Thank you Spankie
    Last edited by andrey002; 08 Dec 2009 at 20:33. Reason: just wanted to make the best solution visible.
  7. Posts : 4
    Windows 7 Home Premium - 32 Bit
       #37
    Here is the latest version - Realtek
    For Win7/Vista
    Version - 6305
    Date - 2009/9/7
  8. Posts : 2,686
       #38
    billdobeans said:
    I have a HP Pavilion zv6000
    amd 64 3200 +
    I used the Realtek AC'97 Audio driver when I had x64 vista business and the sound worked fine.
    I used the same driver with W7 and I get and error that says This device cannot start. (Code 10)
    Has anyone had luck fixing this issue or had the same problem.
    Go to this thread and see if your ID matches and try this solution.
    ZV6000 Audio x64 solved
    It worked on mine.
    You could possibly use the same Vista driver you said worked and modify the inf file the same way. After I modified the inf file I right clicked it and chose install.
    Jim
  9. Posts : 11
    Windows 7 32 bit
       #39
    Hi all
    I have the same problem and can't resolve with the drivers
    6305_Vista_PG537
    Driver_Win7_6111_0922 2
    Vinyl_V700b
    Vista_Win7_R246_x86
    What can i do now?
  10. Posts : 2
    Windows 7 32 Bit
       #40
    i have the same problem i tried installing the driver again after deleting it and uninstalling it but when i try to install the new AC97 driver it says that the manufacturer or this driver cannot be verified and it wont allow me to install the driver.
    is anyone else havin this problem or know a solution to this problem?
