Realtek AC'97 Audio (Code 10)
Page 5 of 5 FirstFirst ... 345
  1. Posts : 1
    windows 7
       #41
    cheese said:
    Can you post the link to that driver (6.01.6293)? I'd like to test. (pvaillion zv5000)
    I too have the 5000. Did you get the link and did it work for you? Can you send it to me if it did. Thanks.
  2. Posts : 2
    Window 7 Ultimate 64
       #42
    Solution for HP zv5000
    HP Pavilion zv5000 Notebook PC series - Download drivers and software - HP Business Support Center
    THis is the link to the audio drivers that works with Windows 7 and HP zv5000
    Good luck
  3. Posts : 752
    Windows
       #43
    Hello there, the latest Realtek AC'97 Audio Codecs are listed on the Realtek's site:
    Realtek
    Accept their terms, click next and in the following screen download the Driver that fits your needs :)
  4. Posts : 2
       #44
    Latest Drivers from Realtek
    The latest drivers cause a Code 10 error. Like everyone else on this thread i too received that error. However the driver at HP website does work fine.
    Matt
  5. Posts : 11
    Windows 7 32 bit
       #45
    Hello
    I have a Intel 82801EB ICH5 - AC'97 Audio Controller [A-2/A-3] and i tried all this drivers:
    Audio AC97 6.0.1.6305
    Audio AC97 6.0.1.6303
    Audio Intel 82801EB ICH5 _ac97_AD188X_AD198X_V5120138901_WDM
    Realtek AC97 Audio Codec Driver A3.97
    Audio Realtek ALC655 AC'97 5.10.0.6020
    I'm sad without sound, how can i do to resolve this problem?
  6. Posts : 1
    If anyone is still interested, I managed to get Realtek integrated AC97 Audio Controller working on an old HP Pavilion a808x Desktop PC that had Winodws 7 Ultimate x64 installed on it. Here's the procedure I followed:
    1. Download the AC97 Audio Codecs from the Realtek site starting at Realtek. The version number is 6305 and the download is a zip file named 6305_Vista_Win7_PG537.zip.
    2. Unzip the file and then double-click on it and follow the prompts to install it.
    3. Reboot the system when prompted.
    4. After you log on you should see a new icon in the system notification area of the taskbar. Click on it to open the AC97 Audio Configuration utility and select the Speaker Test tab and verify sound is coming out of your speakers.
    5. If everything works OK and you see a Program Compatibility Assistant dialog, click the option to indicate the audio Control Panel item is working properly.
    Good luck!
    Cheers,
    Mitch Tulloch, MVP
    Mitch Tulloch, MVP, lead author of the Windows 7 Resource Kit from Microsoft Press
