How do I disable the Windows "DING" sound when copy/paste or cutting?
Page 5 of 6 FirstFirst ... 3456 LastLast
  1. Posts : 2
    windows 7 home 64bit
       #41
    WOW - oh thank you, thank you, thank you!
    I only use headphones and this was really starting to p*ss me off!
    ////KERRRRTWANG///// in my ears at full blast!
    And it was full blast lol
    THANK YOU
  2. Posts : 5,605
       #42
    Hi aegean, welcome to 7F! :)
    Could you be more specific as to what helped your situation?
  3. Posts : 2
       #43
    M8 Free Clipboard
    Which is now muted just by itself within volume mixer.
    Going to contact free app provider and have him put the "bloody loud ding" as an option if he is willing to
  4. Posts : 5,605
       #44
    Thank you for posting back to let us know!
    Your thought of contacting the developer to add that option is a good idea, maybe a volume control also, and a little more information on how the volume works.
    You could point to this thread as backup, and hopefully s/he will agree.
  5. Posts : 21
    Windows 7 Professional x64
       #45
    aegean said:
    M8 Free Clipboard
    Aegean,
    The version of M8 Free Clipboard that I'm using is V12.02
    If you launch the M8 Free Clipboard program, click "Tools", then click "Options" from the drop-down list, it takes you to the Options panel. On the left-hand side there is a box followed by "Sound when new clips are captured". Make sure that box is UNCHECKED, and the "ding" sound will go away.
  6. Posts : 5,605
       #46
    Thank you Scott for that added information.
    Since you hit on the solution, and it was helpful to aegean I took the liberty to ask the Admins/Mods to mark your thread solved.
    It had been several weeks since we last heard from you, and I wasn't sure how you handle your thread/post notifications.
  7. Posts : 21
       #47
    Anak,
    Thank you, I'm still new and didn't realize I was supposed to mark the Thread solved. I have the thread post notification set to email me when new posts are added, which prompted me to post additional info when I read that aegean was having the same problem.
    Thanks to all for the replies and assistance,
    Scott
  8. Posts : 5,605
       #48
    Your welcome Scott!
    Don't beat on yourself too hard. Windows SevenForums etiquette would like thread starters to mark their threads solved when a solution has been reached, but the Admins/Mods don't make it a requirement.
    It helps others save time when they are looking for a solution similar to a problem they are having, and they see the green check-mark.
    It is only recently that they added the "Mark Thread Solved" feature to allow the Thread Starters to mark the thread for themselves
    I tried looking for that feature on some of my old threads, but it may be removed after a certain period of time.
    You can always go to the exclamation triangle to the far upper right of your post to report back to the Admins/Mods.
    Something I learned just recently. The ability to give rep is removed from a thread after 28 days.
    Helpful links:
    Windows 7 Forums - FAQ
    Reputation and Badges [8]
    I find this is easier to use because it goes alphabetically:
    Windows 7 - Tutorial Index
    Steve
  9. Posts : 21
       #49
    And something I just learned now, I didn't know anything about "Rep" points...
    I tried just now to give "rep" points to earlier posters in this Thread, but it has been more than 28 days for all but yours, there's no "button" to add "rep" in the upper right hand corner of the older posts.
    I will do better next time!
    Scott
  10. Posts : 5,605
       #50
    If you notice my older posts on page 1, the rep button is missing.
    You could remember the "earlier posters" when you visit the forums for another answer or just to lurk, and you see an exceptional post by one of them.
