Volume control not active
  1. Posts : 135
    Windows 7 Ultimate x32
    Hi All
    The volume control in the right corner of the taskbar has gone haywire. I tried activating it in the 'customize' settings, but it tells me that it is not activated. How do I activate it, and more specifically, what is the registry fix for this?
    Note: I did try rebooting the PC, but no luck.
  2. Posts : 14,606
    occasionally my volume icon wont show when the computer starts, i find killing explorer.exe, from task manager then re starting explorer.exe from new task in task manager gets the volume icon to show.
  3. Posts : 135
    @Boohbah - Yes thanks, that also helps. Appreciated
  4. Posts : 14,606
    there is an easier way to restart explorer , i have restart explorer in my desktop context menu.
    brink has made a tutorial here...
    Explorer - Add "Restart Explorer" to Desktop Context Menu
  5. Posts : 2
    7 / 64
    boohbah brilliant,
    context menu Plus bat file.
    Thanks for the redirection.
    Easier than using the run command in task manager.
