Realtek HD Changing Jack output reassignments ( FIX )
Page 14 of 21 FirstFirst ... 41213141516 ... LastLast
  1. Posts : 1
    Problem with realtek (p5qld pro)
    Hello
    How can I forse the default winamp/movie player sound to go not only to fron rear, but to central speaker as well ? I prefer sound from 3 sides for such basic things. I need center/front separation only in DVD
    As well I would like to ask how can I manage the basses
    If you need the info - the 5.1 speakers are altec - nothing special
  2. Posts : 1
    Hello guys,
    I just registered and read all 14 pages of this topic, but nothing really solves my problem. I have an Acer Extensa 5210 Laptop and my headphone jack got worn out. I tried regedit but all I can find is shown in the picture below. It would be greatly appreciated if anyone can help me redirect the audio signal throug either my mic jack or spdif jack. Thank you in advance.
  3. Posts : 3
    Windows 7 Pr0 x64
       #133
    I'm sorry of bothering. I saw this awsome post but there is one problem. I tried change pin settings and nothing happened. All settings were just like they used to be. I'm trying get 2 signals cos i need headphones and stereos on sametime and i cant use front panel (aka keyboard haves headphone imputs) I even took backup of those imputs and tried even whit deleting them. Nothing happened...Everything were just like before, if there would be some1 who knows this prob? ALC 892 codecs installed even.
    Yes i'm crazy whit testings :P
  4. Posts : 1
    So after reading all of the posts on every single page I'm very familiar with retasking jacks via the registry but I'm trying to figure out if it's possible for example to retask a rear panel jack, let's just say the black jack, to mimic the _FRONT PANEL_ green jack.
    What I'm trying to ask is, if using multi-stream for output, so I can have 2 different audio streams from green jacks, one front and one rear. Is it possible for me to multi-stream on two of the rear jacks, for example the rear green and the rear black jack?
    I've tried assigning the rear black jack to the front green binary, 02 00 00 00 (Asus P5Q ALC1200 Chipset) but it simply plays what the green jack plays simultaneously.
  5. Posts : 4
    Win7
       #135
    Anyone know how to do these jack output reassignments using a VIA board?
  6. Posts : 1
    Windows 7 Ultimate 32bit
       #136
    hi,
    my green sound output is not working. how I can use line in (blue output) for speaker ?
    thanks
  7. Posts : 1
    hee
    i'm so far that i can change my pins in regedit.
    but when i listen music and movies (everything with music) it returns to deafualt.
    i can restart my pc and it will not return to default but whit music it do.
    how can i fix that?
  8. Posts : 1
    i have logitech x-530. OS windows 7
    and i have problem that front speakers plays normal other very "weak" i tried to change pin00 to 04 00 00 00 pin01 pin02 pin03 to 04 00 00 00 but nothing changed :/
    tried to change ports in realtek manager but i am able to change jus the green one which is front speakers :/
    dunno what to do. please help
  9. Posts : 3
    Windows 7 Pro 64b
       #139
    Still working with 2.56 Realek drivers
    Well, I just registered to thank the OP (and subsequent posters) for this nice trick, and to confirm that it still works with the latest Realtek chips on LGA1155-based mobos with the latest realtek drivers (2.56 at the time of writing).
    As it has been mentionned before, the location of the key depends on your system but with a few searches I found it easily. For me (Windows 7 Pro 64b, Realtek drivers 2.56) it was there :
    HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0001\Settings\Drv6278_DevType_0892_SS10438469
    From there, I just had to change the value of Pin02 from 05 00 00 00 to 04 00 00 00 to replace rear speaker output by a second front speaker output so that i could plug speakers and headphones simultaneously.
    Works like a charm! Thanks again.
  10. Posts : 12,012
       #140
    Likan:
    I will be buying a socket 1155 motherboard with Realtek onboard sound ALC892.
    Have you had problems with it regarding recording? General listening? Microphone input? Any issues generally?
    Contact me by private message if possible.
