Realtek HD Changing Jack output reassignments ( FIX )
Page 7 of 21 FirstFirst ... 5678917 ... LastLast
  1. Posts : 623
    vista x64/ win 7 x64
       #61
    simonfilth said:
    what i don't understand, is why the hell do they work normally when i test them in those 2 applications? but any other thing, only 2 speakers work.
    i'd hang around till 7 is final. Realtek will surely release a good driver. Their chipsets are so common on motherboards they really need to or lose marketshare.
    If you look at the speed they release new driverversions...
    The problem is here with this new layer between hte hardware and the driver that got introduced to enable 7 to switch outputs on the fly.
    If you just try to imagine the enormous complexity of the whole thing, it boggles my mind.
  2. Posts : 9
    Windows 7 Build 7100
       #62
    Thank you so much, this has solved my problems. I thank you humbly for your intense deep registry skills. I applaud you sir.
  3. Posts : 24
    Windows 7 x64 Build 7600.16384
       #63
    Quick question; I'm fed up with the crappy X-FI Xtreme Music and thinking about using my onboard sound. However, I have a 5.1 speaker system and a microphone but there doesn't seem to be enough ports to plug them all in. (I need anologue connexions, not SP/DIF. It seems absurd that you can't use a microphone with a 5.1 speaker system with onboard sound. Or am I missing something?
  4. Posts : 623
       #64
    there should be connectors on your motherboard for linking up another audiojack panel. If not, well you need another soundcard.
  5. Posts : 4
    windows 7 64x
       #65
    Hi;
    I hope someone is still following this thread
    I did change everything as described....I want to connect 2 front speekers
    but whenever I change the values they automatica;;y change back to their defaults after repluging the jack
    If i keep the jack plugged it will not work...if i replug it it goes back
    what should i do?
  6. Posts : 1
    XP
       #66
    Hey
    I'm having this same issue as well. My Speaker jack randomly stopped working, so I'm trying to get my speakers to work through the Line-In or Mic jacks.
    I've been searching for countless hours on how to remap the jacks and finally came across this thread, which describes how to solve my problem, except that I am using Realtek AC'97 on Windows XP, not Realtek HD on Windows 7.
    There's nothing to edit in the "0000" folder.
    Here's what I have:
    If anyone can share the appropriate changes to make for this fix in my situation, I would really appreciate it.
  7. Posts : 63
    win7
       #67
    I have a little sound card issue with the mb on-board realtek sound
    When i use something like skyp, I get the audio from skype through both headphones and speakers, also the person at the other end gets my mic audio, plus my windows sounds, which app are much louder, so if i am talking to them and i click something which ping's or bongs, they get almost deafened.....
    not a biggy, but if anyone else has had this and knows of a cure, please share for the sake of my friends hearing!
  8. Posts : 8,870
       #68
    New Win7 drivers available from realtek here. Realtek
  9. Posts : 2
    windows 7
       #69
    Still doesn't work. So I have to create a binary that I call pin00 and the code is 04 00 00 00 ?
    And the last map is called different, it's Drv5911_DevType_0888_SS1462735a
  10. Posts : 8
    W7 RTM x64
       #70
    i have tested last driver 2.30 on w7 x64 rtm and in some appz still real dont work where exacly i must change those values i have somethink like that in my registry.
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0001\Settings\Drv5911_DevType_0883_SS1043829f]
    "Vol0_RearLineOutWave3_{8a74ffae-8766-480f-af6d-325fcf9ab324}"=hex:00,00,00,00
    "Vol1_RearLineOutWave3_{8a74ffae-8766-480f-af6d-325fcf9ab324}"=hex:00,00,00,00
    "Mute0_RearLineOutWave3_{8a74ffae-8766-480f-af6d-325fcf9ab324}"=hex:00,00,00,\
      00
    "Mute1_RearLineOutWave3_{8a74ffae-8766-480f-af6d-325fcf9ab324}"=hex:00,00,00,\
      00
    "Vol0_RearLineOutWave3_{b25a6526-9703-4117-9d7f-260a5df5cc34}"=hex:00,00,00,00
    "Vol1_RearLineOutWave3_{b25a6526-9703-4117-9d7f-260a5df5cc34}"=hex:00,00,00,00
    "Mute0_RearLineOutWave3_{b25a6526-9703-4117-9d7f-260a5df5cc34}"=hex:00,00,00,\
      00
    "Mute1_RearLineOutWave3_{b25a6526-9703-4117-9d7f-260a5df5cc34}"=hex:00,00,00,\
      00
    "Vol0_RearLineOutWave3_{594ac582-b82a-4024-99e7-dc5b358e0f30}"=hex:00,00,00,00
    "Vol1_RearLineOutWave3_{594ac582-b82a-4024-99e7-dc5b358e0f30}"=hex:00,00,00,00
    "Mute0_RearLineOutWave3_{594ac582-b82a-4024-99e7-dc5b358e0f30}"=hex:00,00,00,\
      00
    "Mute1_RearLineOutWave3_{594ac582-b82a-4024-99e7-dc5b358e0f30}"=hex:00,00,00,\
      00
    "Vol0_RearLineOutWave3_{a5b27de2-40f3-469e-9a4d-2cd8d5d9284d}"=hex:00,00,00,00
    "Vol1_RearLineOutWave3_{a5b27de2-40f3-469e-9a4d-2cd8d5d9284d}"=hex:00,00,00,00
    "Mute0_RearLineOutWave3_{a5b27de2-40f3-469e-9a4d-2cd8d5d9284d}"=hex:00,00,00,\
      00
    "Mute1_RearLineOutWave3_{a5b27de2-40f3-469e-9a4d-2cd8d5d9284d}"=hex:00,00,00,\
      00
    "Vol0_RearLineOutWave3_{185fede3-9905-11d1-95a9-00c04fb925d3}"=hex:00,00,fa,ff
    "Vol1_RearLineOutWave3_{185fede3-9905-11d1-95a9-00c04fb925d3}"=hex:00,00,fa,ff
    "Mute0_RearLineOutWave3_{185fede3-9905-11d1-95a9-00c04fb925d3}"=hex:00,00,00,\
      00
    "Mute1_RearLineOutWave3_{185fede3-9905-11d1-95a9-00c04fb925d3}"=hex:00,00,00,\
      00
    "Vol0_RearLineOutWave3_{093c0065-6b45-4582-87d7-5a6742f6e859}"=hex:00,00,f4,ff
    "Vol1_RearLineOutWave3_{093c0065-6b45-4582-87d7-5a6742f6e859}"=hex:00,00,f4,ff
    "Mute0_RearLineOutWave3_{093c0065-6b45-4582-87d7-5a6742f6e859}"=hex:00,00,00,\
      00
    "Mute1_RearLineOutWave3_{093c0065-6b45-4582-87d7-5a6742f6e859}"=hex:00,00,00,\
      00
    "Mute0_RearLineOutWave3_{8fd300d3-ffe1-44f3-a9eb-6f4395d73c9f}"=hex:00,00,00,\
      00
    "Mute1_RearLineOutWave3_{8fd300d3-ffe1-44f3-a9eb-6f4395d73c9f}"=hex:00,00,00,\
      00
    "Vol0_RtMicInWave_{2bc31d6a-96e3-11d2-ac4c-00c04f8efb68}"=hex:00,00,00,00
    "Vol1_RtMicInWave_{2bc31d6a-96e3-11d2-ac4c-00c04f8efb68}"=hex:00,00,00,00
    "Vol0_RearMicInPinkWave_{2bc31d6a-96e3-11d2-ac4c-00c04f8efb68}"=hex:00,00,00,\
      00
    "Vol1_RearMicInPinkWave_{2bc31d6a-96e3-11d2-ac4c-00c04f8efb68}"=hex:00,00,00,\
      00
    "Vol0_FrontMicInPinkWave_{2bc31d6a-96e3-11d2-ac4c-00c04f8efb68}"=hex:00,00,00,\
      00
    "Vol1_FrontMicInPinkWave_{2bc31d6a-96e3-11d2-ac4c-00c04f8efb68}"=hex:00,00,00,\
      00
    "Vol0_FrontMicInGreenWave_{2bc31d6a-96e3-11d2-ac4c-00c04f8efb68}"=hex:00,00,00,\
      00
    "Vol1_FrontMicInGreenWave_{2bc31d6a-96e3-11d2-ac4c-00c04f8efb68}"=hex:00,00,00,\
      00
    "Vol0_RearLineOutWave3_{185fedfb-9905-11d1-95a9-00c04fb925d3}"=hex:00,80,dd,ff
    "Vol1_RearLineOutWave3_{185fedfb-9905-11d1-95a9-00c04fb925d3}"=hex:00,80,dd,ff
    "Mute0_RearLineOutWave3_{185fedfb-9905-11d1-95a9-00c04fb925d3}"=hex:00,00,00,\
      00
    "Mute1_RearLineOutWave3_{185fedfb-9905-11d1-95a9-00c04fb925d3}"=hex:00,00,00,\
      00
    "Vol0_RearLineOutWave3_{dff21be1-f70f-11d0-b917-00a0c9223196}"=hex:00,80,dd,ff
    "Vol1_RearLineOutWave3_{dff21be1-f70f-11d0-b917-00a0c9223196}"=hex:00,80,dd,ff
    "Mute0_RearLineOutWave3_{dff21be1-f70f-11d0-b917-00a0c9223196}"=hex:01,00,00,\
      00
    "Mute1_RearLineOutWave3_{dff21be1-f70f-11d0-b917-00a0c9223196}"=hex:01,00,00,\
      00
    "Vol0_RearLineOutWave3_{930a479f-0487-4baa-9672-4c7c36c0efb2}"=hex:00,80,dd,ff
    "Vol1_RearLineOutWave3_{930a479f-0487-4baa-9672-4c7c36c0efb2}"=hex:00,80,dd,ff
    "Mute0_RearLineOutWave3_{930a479f-0487-4baa-9672-4c7c36c0efb2}"=hex:01,00,00,\
      00
    "Mute1_RearLineOutWave3_{930a479f-0487-4baa-9672-4c7c36c0efb2}"=hex:01,00,00,\
      00
    "Vol0_RearLineOutWave3_{185fedf9-9905-11d1-95a9-00c04fb925d3}"=hex:00,80,dd,ff
    "Vol1_RearLineOutWave3_{185fedf9-9905-11d1-95a9-00c04fb925d3}"=hex:00,80,dd,ff
    "Mute0_RearLineOutWave3_{185fedf9-9905-11d1-95a9-00c04fb925d3}"=hex:00,00,00,\
      00
    "Mute1_RearLineOutWave3_{185fedf9-9905-11d1-95a9-00c04fb925d3}"=hex:00,00,00,\
      00
    "Vol0_SecondaryLineOutWave_{185fede3-9905-11d1-95a9-00c04fb925d3}"=hex:00,00,\
      fa,ff
    "Vol1_SecondaryLineOutWave_{185fede3-9905-11d1-95a9-00c04fb925d3}"=hex:00,00,\
      fa,ff
    "Mute0_SecondaryLineOutWave_{185fede3-9905-11d1-95a9-00c04fb925d3}"=hex:00,00,\
      00,00
    "Mute1_SecondaryLineOutWave_{185fede3-9905-11d1-95a9-00c04fb925d3}"=hex:00,00,\
      00,00
    "Vol0_RearLineOutWave3_{ba697e2a-bc14-4c0d-9e16-3935f2f15e08}"=hex:00,80,dd,ff
    "Vol1_RearLineOutWave3_{ba697e2a-bc14-4c0d-9e16-3935f2f15e08}"=hex:00,80,dd,ff
    "Mute0_RearLineOutWave3_{ba697e2a-bc14-4c0d-9e16-3935f2f15e08}"=hex:00,00,00,\
      00
    "Mute1_RearLineOutWave3_{ba697e2a-bc14-4c0d-9e16-3935f2f15e08}"=hex:00,00,00,\
      00
    "ChannelConfig"=hex:3f,00,00,00
    "PKEY_RearLineOutWave3"="{5825fe7e-9e68-4ae8-bb4e-985cd649a991}"
    "PKEY_RtSpdifWave"="{7ee5b5da-da14-4668-ba9d-28fe0b51612f}"
    "PKEY_RtLineInWave"="{3a8fe8d0-5eef-4dc2-9172-3c213cf7f746}"
    "PKEY_RtMicInWave"="{d069b450-3fe3-4265-a002-d69a61e1647f}"
    0000 - ist some ati driver too me so 0001 ist realtek
    so i cheange in realtek menager to 5.1 and environment to room
