Realtek HD Changing Jack output reassignments ( FIX )
Page 19 of 21 FirstFirst ... 91718192021 LastLast
  1. Posts : 9
    Windows 7 Professional 64 Bit
       #181
    Hope someone can help me out I just bought a new old stock motherboard because my old one died. It was a different brand motherboard.
    Tis motherboard is still the LGA775. Asus P5QL-EM motherboard
    This motherboard has Realtek ALC1200. I tried the newest version and old versions of the drivers and nothing will let me assign the Audio jacks manually like my old motherboard would.
    I need 2 audio inputs. How can I change the grey output and make it an input?
    It seems like everything in this thread Don't mention how to change an output to an input
    Thanks the Newbie
  2. Posts : 2
    I don't know if your board is physical capable to use both jacks as line-in, chance are that one of em is not hardwired for that. Did you find the registery-keys I suggested in my other post?
  3. Posts : 1
    Windows 7 Home Premium
       #183
    hi
    im new to this form and saw ur post
    im running windows 7 home premium on hp 620
    at first i had a problem where my laptop thought that i always had the headphones plugged in and as such the speakers didnt work
    now thts solved for some reason my speakers arent working, i only get the audio when i plug in headphones in the mic connectors in the front of my laptop i think the reason (im total crap at computers! :P ) is that its jack is labled as "front panel 3.5 mm jack." is there anyway to change this to its internal speakers
  4. Posts : 1
    windows 7 64 bit
       #184
    help pls?
    hey guys, unfortunately, what i tried doesn't seem to be working, i can't even get to the proper folder, so if any of you would be so kind t oexplan this dummy style to me, please do.
    first off, i would like to switch my audio and microphone jack around, since my audio jack just broke today.
    i am using a (dutch!!) win 7 64 bit OS(i don't know wich tho) and my audio sollution is done by realtek.
    if any of you could help me it would be greatly appreciated
  5. Posts : 1
    Windows 8.1 pro 64
       #185
    Windows 8.1
    I have windows 8.1 64 instaled. I dont see any pins in regsiter only the 18 pin. Before win 8.1 i was running win 7 and it worked pefectly i saw all pins but after i upgraded to win 8.1 i dont have pins (only pin18) in register
  6. Posts : 1
    Windows7
       #186
    Hello,
    My problem is I installed Windows 7, the latest realtek drivers 2.73, and there is no settings folder in the registry under 0000, only a drivers folder. I have uninstalled and installed the realtek drivers several times. Does anyone know how to force the pin assignments. I have also searched the registry for PIN(long one there) and realtek, with no success. Thanks in advance
    IP35 Pro and HD Drivers
  7. Posts : 1
    Windows 7 home premium 64bit
       #187
    Similar jack swap problem, Asus X54L
    Hi! I have a similar problem.......I have an Asus X54L laptop, my audio output jack is broken so i want to use my mic. jack for audio output. after reading trough most of the posts, i cant figure out the logics behind this pin changing routine. This is what my regedit looks like at
    "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0000\Settings\Drv6050_DevType_0889_SS80863a3e"
  8. Posts : 1
    Windows 8.1 Pro & Windows 7 Ultimate
       #188
    No 1/2/3/4 Pins
    I'm running at Windows 8.1 Pro
    here's some pics..
    any suggestions??
    it works on win 7 but when i update my windows it not works anymore
    Driver at latest version
    Attached Thumbnails Attached Thumbnails Realtek HD Changing Jack output reassignments ( FIX )-screenshot_1.png   Realtek HD Changing Jack output reassignments ( FIX )-screenshot_2.png
  9. Posts : 1
    Windows 7 Pro x64
       #189
    Fixed this (for some cases)
    Hey All,
    Was running from forum to forum trying to solve this. I have z97 mobo that I upgraded recently, old mobo allowed me to hotswap in windows. Followed various instructions, including those from reaper-x, all to no avail. Changing pins in the registry changed back upon restart. Also, in my registry only 4 pins were listed: Pin15, Pin18, Pin19, and Pin1a. Any attempt to modify or delete those values was undone whenever I restarted.
    What I was trying to do: Have a pair of speakers sitting on my desk and a pair of headphones both take output as though they were the front speaker. I then turn my speakers on or off depending on whether I want to listen through headphones (speakers off) or just in the room (speakers on)
    WHAT WORKED (for me): Brute force! Rather than trying to pick the RIGHT pin, I just took all non-listed pins and set them to binary value 04 00 00 00.
    When I rebooted, I opened up the realtek audio HD program and low-and-behold, my orange jack had become a front speaker!
    If you are so inclined, you could also go through and delete each pin you added to figure out exactly which one caused the switch, or add more pins in the "Pin00" through "Pin0F". Just adding in all the pins as 04 00 00 00 (front speaker) solved my problem so I'll leave it here.
    NOTE: If you are using a setup that already uses the orange jack, remapping this won't help you unless you don't mind losing the center/sub. This will only work if you are just trying to get two 'front speaker' outputs, without a more complex speaker setup.
    Hope this helps!
    x-posting this to some other websites that I looked for assistance on.
  10. Posts : 260
    Windows 7 Ultimate 64bit
       #190
    Where there's a will...
    Wow, guys!
    I mean, wow!
    Whoever discovered this needs some big time credit!!!
    Does this only work if you have HD (etc) audio 'devices' (speakers and stuff) that you're connecting to?
    I'm trying to see if I can do some kind of
    app A -> audio device A (speakers)
    app B -> audio device B (analog headphones in port 1)
    I've just bought an SPDIF cable and subsequently discovered my old sony minisystem is optical OUT, not in. any suggestions for aspiring music producer kit (Hardware)? Do I need an amp and a mixer and some cabs for live setup?
    I've been told previously that what I'm doing CAN'T be done (physically impossible due to underlying audio bus), and I fear that may be why I (and some others thread posters, ie bartrum) can't do some of this AWESOME stuff that y'all are doing...
    Couple of q's in there.... I'll add one more to close
    How do you identify which ALC (97,297,997,665) you have ? Found datasheet(s), they should help SOMEONE work out who can do what....
    Very pleased for everyone (anyone!) that's had success with their audio endeavours - sure you all worked hard for your efforts, you deserve your rewards...
