Realtek HD Changing Jack output reassignments ( FIX )
Page 2 of 21 FirstFirst 123412 ... LastLast
  1. Posts : 910
    Win 7
    MaDMaxiBo said:
    Hi
    Can i solve my problem with this options ?
    problem is this ...My front audio output is not working...
    it says not attached even i put headphone in...
    i thought may be i can change rear autput with front...What should i do ?
    Wouldn't hurt to try, but i would try the latest drivers first if you have not.
  2. Posts : 12
    Windows 7 x64 7000
       #12
    im using latest driver. R 2.21
    and i dont have the codes : DevType_0888_SS147b1083
    i added manually and this is how it seems : What else can i do ? fornt jack still doesnt work.
    Attached Thumbnails Attached Thumbnails Realtek HD Changing Jack output reassignments ( FIX )-audio-reg.jpg
  3. Posts : 910
    Win 7
    You want the Drv5821_DevType_0885_SS1458a002 key.
  4. Posts : 12
    Windows 7 x64 7000
       #14
    i quit..
    i realized that there is nothing to do with regs for my problem...
    just jack is not working.
    Thanks anyway.
  5. Posts : 23
    windows 7 64 bit and windows vista 64 bit
       #15
    thru software i am able to do this.. realtek software u can choose which pin to act aas what.. u can even interchange mic with head phone.. front with back.. anyway u want..
    and its simple and very easy ..
    this is like.. all techhy
  6. Posts : 910
    Win 7
       #16
    This "techy" thread is for those who can't get it to work through the software.
  7. Posts : 16
    Windows 7 Professional x64
       #17
    Neilsouth said:
    Atleast now i can change the ports by editing the Pin binary numbers! . If you can't change jack output assignment this will fix it oh and it sounds great ., i turned my Center/Subwoofer to front speaker out put so my rears are stereo just like my fronts and not speaker filled rubbish
    Neilsouth can you tell me how did you get the sounds from the rear speakers without using the speaker fill option can you explain it 2 me cz i speaker fill sound suckz
  8. Posts : 11
    I have a big problem now. Yersterday, I installed my windows 7 RC1 7100. And no sound.
    I have checked the sound driver several times, and it doesnt work at all although I have plugged my speaker in. Uninstall then reinstall. OMG. Here is my problem, help me:
    I have tried the regedit method, but I cannot find the way to the address.:
  9. Posts : 11
    Someone helps me. Pls.
  10. Posts : 623
    vista x64/ win 7 x64
       #20
    I wrote a little thing to set Audio endpoint on the RealtTek HD without setting registry settings. Win 7 finally lets us set endpoints on the fly without restarting the apps, the little app will let you change audio endpoints system wide, either with the gui or with commandline switches
    It's really hardwired for English only:
    http://www.petrossa.com/SetRealtek.rar
    or the source on codeproject
    CodeProject: Set Audio Endpoints System Wide Vista/Windows 7. Free source code and programming help
