Realtek HD Changing Jack output reassignments ( FIX )
Page 3 of 21 FirstFirst 1234513 ... LastLast
  1. Posts : 11
    How can I run it? It doesn't work. I open it and nothing happen. I cant even click on it. :|
  2. Posts : 623
    vista x64/ win 7 x64
       #22
    a. do you run it as admin or as user?
    b. are you sure you have the driver for Realtek HD 2.22 installed?
  3. Posts : 11
    I run it as admin and im pretty sure that I have installed the latest driver. After a moment, a window pops up and notifies that there is something wrong.
  4. Posts : 16
    Windows 7 Professional x64
       #24
    i tried tht software no good
    im using da lastest driver
    my one is alc888
  5. Posts : 623
       #25
    i've had more helpful feedback then 'something is wrong'. It helps if you just tell me what's wrong according to the software, that would help me greatly to find out what the problem is. It's amazingly the reason why the window pops up, to tell you what goes wrong.
  6. Posts : 11
    Here is the error:
    Details
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.InvalidOperationException: Enumeration already finished.
    at System.Array.SZArrayEnumerator.get_Current()
    at AudioConfigManager.Form1.lvEndpoints_Click(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.ListView.WmReflectNotify(Message& m)
    at System.Windows.Forms.ListView.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4918 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    AudioConfigManager
    Assembly Version: 1.0.3411.33848
    Win32 Version:
    CodeBase: file:///C:/Users/Hoang%20Bui/Documents/Downloads/Compressed/SetRealtek.exe
    msvcm90
    Assembly Version: 9.0.30729.4918
  7. Posts : 623
       #27
    tnx, that's weird. It says in fact that the Audio Endpoints are undefined. would you be so kind as to post a capture of the soundapplet opened on the playback page?
    It should look like (see picture)
    Attached Thumbnails Attached Thumbnails Realtek HD Changing Jack output reassignments ( FIX )-realtek.jpg
  8. Posts : 11
    Sorry for keeping u waiting. Here is my capture.
  9. Posts : 623
       #29
    tnx for your assistance. My soundapplet only contains 2 outputs and was hardcoded for that. I'll make the app selfaware of the number of outputs...
    Watch this place for an update if you want to have it
  10. Posts : 1
    Win7
       #30
    Is there a way to do this with AC'97 drivers?
    I know its the problem because whenever I test the speakers the "Front two" make no noise then the "Rear two" makes the noises and I can't use surround sound so I hear no noise at all unless I'm able to flip them. Please help.
