VIA HD Audio Deck expert mode
  1. Posts : 3
    64
    Hello,
    I cant switch mode on Audio deck because i havent button for switch to expert mode, i need it for settings 5.1 woofer and more efects before reinstall Windows i have it
    I install driver :
    http://www.viaarena.com/Driver/v8700a_20100923.zip
    my VIA audio Deck
    i need it
    Informations
    Package Version 8.7.00.30
    Codec version VT1718S
    Driver version 6.0.1.8700
    THANKS FOR HELP !!!
  2. Posts : 2,240
    Windows 7 Ultimate 64 bit
    Update to the latest sound driver from VIA...
    Then again it maybe corrupted....re-download the driver and save to desktop. Then uninstall current sound driver and reboot...then install the driver from desktop.
  3. Posts : 3
    64
    But, this
    is last driver and i reinstall it 10 times i must find other version for install
  4. Posts : 2,240
    I have the exact same onboard sound by VIA and the same driver.
    Where are you downloading the driver from....your mobo manufacturer or from the VIA website?
  5. Posts : 2,240
    Going back over your original post...I'm a bit confused. You had the expert mode prior to a re-install of windows...is that correct. The you re-installed windows and now you don't have the expert mode...is that correct. If so, have you downloaded the latest chipset and BIOS version for you mobo. That may help solve your issue.
  6. Posts : 3
    64
    I uninstall all drivers and restart pc next i install
    http://www.asrock.com/mb/download.us.asp?Model=M3N78D&o=Win764
    this driver from original my board website and finally work it
