SB Live! 24 Bit (Internal)- Dead Subwoofer
Page 2 of 2 FirstFirst 12
  1. Posts : 98
    Windows 7 64 BIT
    Sassa said:
    Try to install console launcher...
    I did that and solved subwoofer problem.
    Seriously i dont have acces at Bass management and Equalizer why ?
  2. Posts : 4
    Windows 7 Ultimate 64bit
       #12
    Have you done what I've done ?
  3. Posts : 1
    windows 7 64bit
    Hi-.. i've done as you wrote..
    But (as the last time) when i lunch any creative panel it shows:
    Hardware not supported.. (and so on..)
    Have you a 64 bit version or 32?
    According to me, you have 32bit version..
    In 64bit there is no way to activate subwoofer redirect??
  4. Posts : 2
    win7
       #14
    i cant belive
    how you guys resolve this i mean im disperate i hate win7 pls someone make a turorial or something i did everyting and i cant find the solution
  5. Posts : 2
    win7
       #15
    finaly i did resolved !!! you have to instal drivers manualy , and you need do downlode media source CMS_PCAPP_LB_3_30_21 , then install media go and its realy works so iff you have win7 32bit version you downlode drivers from xp32 version and if you have win7 64 version downlode drivers for xp64 version if somebody need help email me at revengerro@yahoo.com i will gladly help anyone becouse i search for days for this so ...( fu.. creative suport !!!! they su.. )
  6. Posts : 98
    Windows 7 64 BIT
       #16
    The solution for X64 win 7
    Is not perfect perfect perfect
    But all option is here
    SB P17X Series Support Pack 2.6 (02/16/2010) - Aud... - Creative Labs
    (Unofficial package software that use Feature xfi..)
    The only negative thing when i use level and frequency cut off, some crackling
    But is not always, and all tweak sound reset each reboot
    BUT I ENJOYS THIS PACKAGE ! ! ! ! ! ! ! !
    Its the way or new hardware 200 $ lol
    FOR XFI
    X-Fi Titanium series WHQL driver v2.16.0004.6 - Creative Labs
    Last edited by p1tcho0; 28 Mar 2010 at 11:38. Reason: OUTDATED LINK HERE IS THE NEW LINK ^^
