Too loud volume
  1. Posts : 1
    64 bit Windows 7 Home Premium
    Too loud volume
    I have a Corsair Vengeance 1500 headset, and when I use it it's always too loud. Even when I turn the volume down to 1, it's too loud at times. I have tried it on 3 different computers, and it happens on all of them. I have gone to the control panel and tried to turn down all sound options, but it doesn't help. What should I do?
    This is a USB gaming headset, from what I see. This most likely has it's own built in amplifier as it's not using the PC's sound card. Check with Corsair on how to control the volume.
  3. Posts : 1,413
    On that note http://www.corsair.com/media/cms/dri...iver_1-1_1.exe
    Do you have the driver installed? Or are you just using the Windows driver?
  4. Posts : 644
    Windows 7 home premium x64
    Sorry to state the blinkin' obvious but I suppose you have adjusted ?
    This.
  5. Posts : 1,413
    This.
    I'm glad someone went there, I was afraid it was just TOO obvious.
