Stereo mix problem
  1. Posts : 5
    Stereo mix problem
    Hello, I'm new here, If I posted it in the wrong section please move.
    Anyways I have problems with my Stereo mix, Everytime I play music the volume of the stereo mix is always "Green"
    Also I normally use Stereo mix to do commentary when I make videos
    But every time I press "Listen to this device" I hear this repeating sound over and over again, It gets very annoying *I have no music playing or anything at all* It just very an annoying sound
    I do have conexant HD Audio, I have tried uninstalling it and reinstalling it, Still has the same problem AFTER I use Stereo Mix. Any help will be nice :)
    It looks like you have active inputs on both the Rear Microphone and the Line, as it states "Ready". I don't have anything connected to my line or microphone ports and they show "Currently Unavailable".
  3. Posts : 5
    Hm... I do have something plugged in there which is my sub woofer, Do you think that's my problem?
  4. Posts : 8,135
    Sub Woofer plugged into an "Input"???
  5. Posts : 5
    It's plugged in my pink jack.
  6. Posts : 8,135
    That is the microphone input jack, not an output jack. A speaker should not be plugged into that. Also, same with the Blue Line In.
  7. Posts : 5
    So I'm supposed to unplug whatever is plugged in the pink jack?
    Edit: It's still making that annoying repetitive sound when i click on "Listen to this device" and it sounds like my speakers are going to blow up.
  8. Posts : 8,135
    What is the Roxio Game Cap that is shown on the Line In?
    What type of speakers do you have and where are they plugged in?
  9. Posts : 4,161
    Windows 7 Pro-x64
    Turn off "Listen to this device" unless you have a line-in input connected.
  10. Posts : 5
    It's a line for my roxio game capture, The sound and stuff I have logitech speakers, Don't know what the type of logitech speakers it is though, All I know is that, It has a sub woofer. I used to have them plugged in, In the Green one and the Pink one, but I disconnected the pink one though
    Yeah I have that part off, I turn it on to see if that annoying sound is still there.
