UAC popup without sound
  1. Posts : 23
    Windows 7 Ultimate 64 bit SP1
    I reinstalled Windows 7 Ultimate x64.
    I noticed that UAC popup is not accompanied by any sound.
    I did all possible checks .. the menu sounds is ok.
    I reinstalled the audio driver, no improvement.
    Can someone help me with any solution? I want UAC popup, be accompanied by that particular sound.
    I mention that a Microsoft representative sought by telephone, to fix my problem, but failed
    Thank you!
    This is not a problem with your sound card or audio drivers.
    The UAC is not assigned a sound by default. You must manually set whatever sound you want for that function.
    Go to the Control Panel/Hardware and Sound and then click on "Change System Sounds". In the Sound section of the panel you can assign a sound to the UAC.
    Sounds - Change
  3. Posts : 23
    Thanks for your answer!
    But the problem was not solved.
    When I clicked on "test", I can hear that sound UAC, but after I select Apply and OK .. no sound is heard when I open any application that implies the UAC.
    Please more, you have another idea? Bothering me a lot that you do not hear sound from UAC.
  4. Posts : 8,135
    That is the only thing I know.
  5. Posts : 23
    thanks fireberd!
  6. Posts : 2
    i have the same problem.have you resolved?how?
    every other PC sound works.
  7. Posts : 2
    kronikim,have you installed Bitdefender 2013,by chance?
    this problem occurred after installing bitdefender 2013?
  8. Posts : 23
    Yes, I identified the problem. BitDefender 2013 is the reason
  9. Posts : 1
    Windows 7 x64 Pro
    A bit off topic but I changed my UAC wav today to something a bit more ominous. The inception boom
    Attached for anyone who wants it.
    UAC popup without sound Attached Files
