Windows 7: No onbord sound. Help!!!
05 Sep 2009   #1
mass93
Hey guys whats up. so i got a bit of a problem here, i have zero onboard sound . i have a p5gc-mx/1333 asus motherboard. i installed the drivers for it,( vista ones 32 bit because there is no win.7 drivers yet.) and the setup runs prefect no problems..... but when i go to my sound and audio in the bottom right corner, it says no headphones/speakers are plugged in... i no that it is the wrong driver but i have installed win.v drivers for win.7 and had no problems...if it is simply a driver issue, do i just wait until they come out for win.7 or is there an alternative for me? thanks guys
mass93
05 Sep 2009   #2
mckillwashere
Windows 7 x86/x64, Server 2008r2, Web Server 2008
uninstall the drivers see if the default windows driver works i know it does for my maximus formula
06 Sep 2009   #3
king44
Windows 7 x64
Try to install the drivers in compatibility mode (winvista sp1) or try to extract the drivers from the .exe file and use device manager to update the driver manually.
06 Sep 2009   #4
dw96
Windows 7 Home Premium [64-Bit]
Quote   Quote: Originally Posted by king44 View Post
The guy can also set the application itself to run in compatibility mode all the time. There should be some shortcut in the startup folder. Right Click>Properties>Compatibility>Run in Compatibility Mode for Windows Vista SP1/SP2.
18 Nov 2009   #5
shibby73
Windows 7 (7600)
same problem with studio 5.1
I have the same problem ! somebody please help me! they have updated the drivers on the website and even the windows 7 driver does not work . have tried moving pci slots and just swapped the sound card from a sb 5.1vx which would not work either
18 Nov 2009   #6
tuti05
you could try right clicking the sound icon, click playback settings and next to that speaker icon right click choose show disabled devices and then enable if anything shows up
18 Nov 2009   #7
shibby73
Windows 7 (7600)
Its the sound card itself that has the problem.
Creative Sound Blaster Audigy FX Sound Card, no playback/recording
Hi, I recently purchased the Creative Sound Blaster Audigy FX and am having problems getting it to actually play any audio or record any sound. I've browsed other threads with similar issues on this board and as such have disabled my motherboards onboard audio in my BIOS settings, have...
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
