Headphone volume too low !!
Page 2 of 2 FirstFirst 12
  1. Posts : 8,135
    How does the speaker system's headphone jack work? It sounds like it is being amplified by the speaker system's amplifier and the reason its loud enough.
    Maybe there is some problem with the PC's sound hardware that the speaker system is covering up since it has a built in power amplfier. Based on what you've reported, that the volume level is low at both the front panel headphone jack and the rear speaker jack with more than one headphone, it does appear that there could be a hardware problem with the sound, assuming the volume levels are set up in the PC.
    One thing to check, go to the Sound Panel, Recording section and make sure the System Mixer is set as the recording device. This is a long shot but worth checking/trying.
    Also, the Intel web site lists a different file version of the RealTek for this motherboard. Generally, the PC or Motherboard vendor's drivers are the preferred. Intel - 6.0.1.6602_PV.exe
    http://downloadcenter.intel.com/Deta...*&DownloadType=
    My old PC used an Intel DP35DP motherboard and I always used the Intel supplied sound driver for it and didn't have any problems.
  2. Posts : 7
       #12
    I've installed that version.. still low on volume..
    something is not right !! i tried everything to boost some volume into headphone.. !! still not working
  3. Posts : 208
    Check the "Enhancements" tab when you double-click on your headset in "Playback Devices". Try checking "Loudness Equalization", that's how I squeeze a few extra decibals from time to time when the source audio is bad.
  4. Posts : 8
    Windows 7 Ultimate SP1, x64
       #14
    I had the same problem
    I had the same problem, I got a new laptop and noticed that while the speakers were loud, and headset didn't sound loud on just THIS laptop. IT was fine with the old one. I cross checked and played back a clip on both of then, one by one and listened. Volume was too low on the new one. I figured it was because of the Realtek soundcard which was somehow doing that to headset.
    SO... I got a USB headset, and the volume is back to normal and actually sounds better. Since it's a USB device, the soundcard can't control it. I suggest you buy a GOOD quality USB headset.
  5. Posts : 1
    Windows 7 home Premium 64-bit
       #15
    Same problem hear with low sound when I plugg in my headphones in my laptop. I think it was a update that went wrong, cause my comp just updated and when I played a media file thats when i noticed the sound was really low before i updated my computer! HELP!!!
