Missing Sound Scheme(s)
  1. Posts : 24
    Win 7_x64 Linux Kubuntu Jaunty_x64
    I suddenly found my Windows Sound has no sound scheme.
    Things were fine after I installed the OS and the only change I made since then was switch back and forth between a couple of windows schemes that came with the OS.
    The entire list is blank under sound and when I try to add a sound scheme the list is a blank not even windows default.
  2. Posts : 72,059
    Hello BeepBeep,
    The default location for the default Windows 7 sounds are at C:\Windows\Media. It may have been changed by mistake.
  3. Posts : 24
    Brink said:
    Hello BeepBeep,
    Thanks.
    That was not the problem; a registry entry had been deleted. Ran upgrade and it got fixed.
  4. Posts : 72,059
    I'm happy to hear that you got it sorted. Thank you for posting back with your solution. :)
