Help seting up Audio through HDMI to HDTV
  1. Posts : 346
    Windows 7 Pro X64
    My system specs are listed for my rig before I say anything that is what I am running ATM
    Current video card has an HDMI and with space limitations been trying to get my 40" Toshiba to work as a monitor. I been trying to get audio to the set and found the options in the Gforce control panel, but it goes on to ask for the device in windows to be switch and windows dose not have a listing for such a device.
    So I am not sure how to finish this up and use the TV as I wish. So is it possible to do so and if so I could really use the help.
  2. Posts : 25,847
    Go to the Start Orb and type in Audio and then select Manage Audio Devices. Right click HD or HDMI as default. Right click again and select Test. If it works you will hear the test.
  3. Posts : 346
    Windows 7 Pro X64
    It is not listed as an option when I checked before and then now it still was not.
  4. Posts : 8,135
    According to what I see, your video card has built in HDMI audio. First thing is to verify you have the correct video card driver, use the ASUS supplied driver to start with (other NVIDIA drivers should work but use the ASUS supplied initially). Go to the Control Panel/Hardware and Sound and finally the SOUND Panel/Playback section. The HDMI should be listed as one of the playback options and if an HDMI cable is plugged in, many will automatically switch to HDMI as the default playback device. If its not set as default playback device with a cable connected, set it as default. If you still do not get HDMI audio, there may be a hardware problem with the card.
  5. Posts : 25,847
    The only thing I can think of is you don't have the proper cable plugged into the proper place. Double check you video card instructions.
  6. Posts : 6,879
    Win 7 Ultimate x64
    Actually it doesn't. What it has (and all Nvidia 8xxx/9xxx series with a HDMI port) is audio passthrough. It doesn't have built in audio like the AMD HD series and the newer Nvidia cards. To get sound over HDMI from that card you have to connect it to the SPDIF header on the motherboard or sound card,
    Guide: 8800GT/9800GT/9800GTX Sound over HDMI (Now including Creative cards)
  7. Posts : 346
    Windows 7 Pro X64
    So where can I get that wire I will need? I don't have anything extra to cut even if I was willing to cut stuff from in the case.
  8. Posts : 25,847
    My understanding your card should of come with it.
    Packaging
    Package ContentsEN9800GT HB/HTDI/512M
    Driver Disk
    User's Manual
    HDTV Cable
    Power Cable
    DVI to VGA/D-sub Adapter
    DVI to HDMI Adapter
    S/PDIF Cable
    http://www.newegg.com/Product/Produc...82E16814121268
  9. Posts : 8,135
    As this is an old, discontinued, video card, that gets HDMI via an adapter, along with the needed S/PDIF connection to the PC's motherboard (if the motherboard even has an S/PDIF connector) is would probably be better to upgrade to a new video card that does have built in audio and HDMI.
  10. Posts : 346
    Windows 7 Pro X64
    That would require more money then I could afford at the moment.
    As for the cable if it did come with the box, then I can only say it is in storage and not something I can find or pull out easily. i just recently moved and don't have all my stuff out or know where it would be.
