Sound Error: no audio devices are installed - hp pavillion dv6500
  1. Posts : 2
    windows 7
    hi all, im new to this site. I have problem with my sound. There were no problems before but now whenever i try to put the volume higher an error alert saying no audio devices are installed comes on. i have looked around and tried going to services.msc but it didnt work. I really cannot stand having no sound!
    thank you all.
    ss0900
    Attached Thumbnails Attached Thumbnails Sound Error: no audio devices are installed - hp pavillion dv6500-audio.png
    What did you do to cause the problem, if you know? Did you do a complete reinstall? Have you disabled the audio in the BIOS? Did you run a "Registry Repair" program?, etc.
  3. Posts : 2
    windows 7
    fireberd
    thanks for replying. I turned the laptop on and off and the sound went with it. Thanks
  4. Posts : 8,135
    Ouch. Try a System Restore and see if that brings it back, as a first step. System Restore can be accessed from Start/Programs/Accessories/System Tools. Select a restore date that is prior to whatever happend. System Restore will not delete any user data or e-mails, but if something was installed or updated you will have to do that again.
