Windows 7: Problem Sound (ALC880) + DVD LG
21 Jan 2009   #1
Cappers
Windows XP + Windows 7 Beta1
Hi all.
DVD is - LG HL-DT-ST DVD-RAM GH22LP20
SOUND is - ALC880 8 channel audio
Dvd is installed with Windows7 installation. But somewhere down the line, the drive disapear's from my computer, & when you check Devices, it has a yellow triangle on it. (Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) ).
Cannot get a driver to work for the above sound hardware.
Anyone help please Apprtd.
21 Jan 2009   #2
darkassain
Quote   Quote: Originally Posted by Cappers View Post
Hi all.
have you tried removing the driver??
right click it and then click unnistall...
restart and that should solve the problem (as windows should automatically find the drive and install the driver...)
21 Jan 2009   #3
Cappers
Hi
Yep, tried that goes as if installing then fails. On 1st install dvd's are ok, it installs them with a beta file (cdrom.sys) but as i said before somewhere down the line it decides not to use this file, says it's not suitable.
Thnks anyway.
17 Sep 2011   #4
belmandos
Windows 7 Enterprise
Realtec ALC880 sound card to solve the problem to install R version 1.97 will fix the problem.
Link to download: REALTEK - Download driver for ALC880
I've tried it I succeeded.
Regards ..
Isa Karahan
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: https://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
Windows Media Player Problem - Sound/skipping problem.
Oh look, another windows media player problem, lol. Well, it's something really weird, at first i thought it was just my computer being all slow or the file was messed up, No matter what movie or format i play it makes this weird screeching noise. It also lags pretty bad. I tried the scans, i did...
Music, Pictures & Video
Sound problem with New RAM
Hi, Recently I bought new RAM from Crucial - 4GB kit (2GBx2), 240-pin DIMM, DDR2 PC2-5300 upgrades for Dell XPS 600 Desktop/PC, CT519124 from Crucial.com I went to install it, only to find my sound went all crackly until disappearing altogether after a few minutes. I've been on to Crucial,...
Hardware & Devices
