stange problem
  1. Posts : 7
    stange problem
    I bought a software to read the texts in many language called naturalreader , and download some of speech engines by some of language as french and italian and so on
    then the program worked perfectly , but when the electric current was cut off abruptly and my computer restart I surprised by a mistake in my program when i opened it i found this message
    First time to use natural reader , please right click Natural reader icon from your desktop , and choose run as adminstrator
    and when i did ok i foundnd another error message says:
    no voice is detected in your system , please install the voice first
    i uninstall the program totally by uninstall programs and reinstall it but the problem remained the same
    i hope to find a problem to this problem instead of setup a new windows or usinng system restore
    thank you
  2. Posts : 12,364
    8 Pro x64
    The quickest method may to be use a Restore Point.
    This is different to a full system restore.
    Select a restore point just prior to crash when you knew the machine was working.
  3. Posts : 7
    thank you ,I was thinking in restoring my system as i said in the topic but factually I like to understand the problem and solve it
