Why are all my recordings low volume and garbled?
Page 1 of 4 123 ... LastLast
  1. Posts : 37
    Windows 7 Home Premium 64-bit
    If I use the Sound Recorder the recording level barely moves and the sound is clear for only 30 seconds and then gets very garbled. I also had a Roxio program on my computer that had the same issue with garbling. I uninstalled it and reinstalled it thinking that was the problem, but it did not help. What do I do?
    Could you please update your System Specifications by downloading Speccy, and then going to UserCP, and copying all the information from the Speccy program, into your Edit System Spec fields.
    Could you please also upload your a .NFO file of your system by going to:
    Start > Type "msinfo32" (without quotes)
    File -> Save (when msinfo32 has opened)
    Save the .NFO file to your Desktop
    Then create a Zipped Folder and place the .NFO file within the folder
    Upload the folder with the file to this thread, by creating a new post and using the paper clip icon within the area in which you write your posts for this thread.
  3. Posts : 37
    Thanks, I updated with Speccy, too.
    OS Name Microsoft Windows 7 Home Premium
    Version 6.1.7601 Service Pack 1 Build 7601
    Other OS Description Not Available
    OS Manufacturer Microsoft Corporation
    System Name OWNER-PC
    System Manufacturer TOSHIBA
    System Model Satellite L745
    System Type x64-based PC
    Processor Intel(R) Core(TM) i3-2310M CPU @ 2.10GHz, 2100 Mhz, 2 Core(s), 4 Logical Processor(s)
    BIOS Version/Date INSYDE 1.60, 5/17/2011
    SMBIOS Version 2.7
    Windows Directory C:\windows
    System Directory C:\windows\system32
    Boot Device \Device\HarddiskVolume1
    Locale United States
    Hardware Abstraction Layer Version = "6.1.7601.17514"
    User Name Owner-PC\Owner
    Time Zone Eastern Daylight Time
    Installed Physical Memory (RAM) 4.00 GB
    Total Physical Memory 3.95 GB
    Available Physical Memory 2.49 GB
    Total Virtual Memory 7.90 GB
    Available Virtual Memory 6.23 GB
    Page File Space 3.95 GB
    Page File C:\pagefile.sys
    Could you upload your .NFO file by using:
    Start
    Type within Search Programs and Files -> msinfo32
    File -> Save - Save Location = Desktop
    Create a Zipped Folder, by going to Desktop and then Right-Clicking anywhere; drop-down menu should appear, then select New -> Compressed (Zipped) Folder
    Drag the .NFO file into the folder, and then upload to this thread by, using the paper clip icon within the Quick Reply at the bottom of this page.
    Attached Thumbnails Attached Thumbnails Why are all  my recordings low volume and garbled?-capture.jpg
  5. Posts : 37
    Not sure how to do that. When I clicked on the paperclip then clicked browse it said it was downloading, but nothing shows up in this reply block. Also, zipped folder wasn't an option, but "Create New Folder" was.
    Is your Context Menu like this?
    See Screenshot
    Attached Thumbnails Attached Thumbnails Why are all  my recordings low volume and garbled?-context-menu-compressed-folder-create.jpg
    Spritsailor said:
    I have going to say to find the latest version of your Sound Card driver, but this doesn't seem a viable option unless you contact your computer manufacturer, according to the support site for your Sound Card.
    Conextant Support
    Are you recording both sound and video or just sound?
  8. Posts : 37
    x BlueRobot said:
    Spritsailor said:
    Forgot to ask why you needed all this done.
  9. Posts : 37
    Just recording sound.
    Okay, and I wanted to see the date of your drivers.
    Are you just using Windows Sound Recorder? What hardware are you using to record the sound input?
