Audio jack stuck in PC input jack...?
  1. Posts : 2
    Hello my dear fellow windows 7 users!
    A few days ago, one half of the jack of my external speakers got stuck in the female jack of my PC laptop.
    I am using Realtek HD audio, and I wanted to ask whether it is possible for me to somehow disable the jack and have my audio played through my normal inbuilt laptop speakers, seeing as I will be needing audio from my computer as soon as possible.
    Here is a snapshot of my audio devices - and as you can see the speakers and headphones are under one device so I can't switch between the two..
    Please help
    Thanks alot.
    You will need to get the broken piece out. Sometimes a strong magnet will dislodge it. Some RealTek's have a control panel that will allow you to reassign jacks, but I don't know if that will even do you any good.
    If you have one it will be located in Start/Control Panel/Hardware and Sound.
