How to enable sound when plugging/unplugging charger for laptop.
  1. Posts : 2
    Windows 7 Home Premium 32bit
    I was wondering if anyone is familiar with a method to enable sounds for when you plug in or remove a charger connected to your laptop. It is not a problem with my pc, but is an option that is not available for me which i would like to install to let me know if i accidentally unplugged the charger, particularly if I'm working on a full-screen feature. Any help would be appreciated.
    I have Windows 7 home Premium 32-bit installed.
    In the System Sounds, there is an option for device connect or disconnect. This will probably do what you want. You will have to assign a sound for those functions.
    The System Sounds panel can be accessed from Start/Control Panel/Hardware and Sounds. Click on "Change System Sounds".
  3. Posts : 2
    Didn't work but thanks for the suggestion. I don't think it is available in this version of windows... maybe it will be available in the next.
