no sound from my speakers
  1. Posts : 12
    Win7x64
    hello!
    do you have any idea why there is no sound from my Logitech LS11 Speakers ?
    mobo: Gigabyte GA-880GM-UD2H
    video on board: ATI Radeon HD 4250
    sound device: https://i.imgur.com/IjdPS.png
    thanks!
  2. Posts : 264
    Windows 7 Enterprise x64
    Test these speakers with other devices like DVD player, Ipod or any other computer. If the speakers are working with other dvices, then try testing the speakers on another USB ports on this computer. If still no sound, test any other external devices like mouse & keyboard on this same usb port.
    Let us know the results.
  3. Posts : 6,879
    Win 7 Ultimate x64
    The one highlighted is the audio built into the onboard HD 4250, and only used for HDMI audio. No idea what the USB audio device is, webcam possibly. The onboard audio for your speakers (which are not USB speakers) is the last one, Realtek.
    Make sure that the speakers are connected to the green jack at the back of the computer, and that the power adapter is plugged in. Then open the Windows playback properties and make sure that the Realtek audio is set as the default playback device.
  4. Posts : 12
    Win7x64
    the speakers are not usb connected, they have a power plug and an audio jack
    their connections work and the speakers were working as they are connected now, before installing win7!
    what the problem can be??
  5. Posts : 12
    Win7x64
    anyone???
  6. Posts : 8,135
    The first thing I see is that Digital is set as default playback device. Unless you have a digital connection to some other device, like a surround sound system you will never get any sound.
    The Speakers (your PC sound card) needs to be set as the default playback device.
  7. Posts : 12
    Win7x64
    I first enabled "Realtek Digital Output (Optical)" and then I got sound from "Realtek HD Audio 2nd output"
    solved, thanks!
