Windows 7: Sound problem
27 Sep 2009   #1
cmdryker
Windows 7 Enterprise x64
Sound problem
First let me welcome myself to this forum, My name drew from st. louis (go cards), Problem is when in a chat session , either chatroom , irc or instant messenger, i would like for others to be able to hear my sound such music or anything, on my last system a few years back i install a loop back cable plugged into the line-out on sound card ,with other end going into mic port, this worked perfect, question is , can this be done with out the cable as i have lost it and have no mic,,,If need be i go buy another:
motherboard is ASUS A8N32-SLI Deluxe 4gigs ram not much on onboard anything, but sound seems ok,
Audio: Realtek ALC850 8channel
any idea,??
27 Sep 2009   #2
SquonkSC
Win7 Build 7600 x86
Quote   Quote: Originally Posted by cmdryker View Post
any idea,??
Google for "Virtual Audio Cable". 1st link is the homepage
The latest version is from 2007, so I don't know if it works on Win7.
good luck
28 Sep 2009   #3
cmdryker
Thanks,,
It installed find but diver wasn't signed so it wouldn't install, so i disabled driver signature in group policy editor, then installed and worked, but i'm not to horny about system ignoring file signature signing, so i just went to wal mart bought a 3 dollar cable. I do appreciate the help though, it was one those liittle problems where you don't lose to much sleep over.. lol..
BTW on my first post in this forum i posted about free file i found that is best and fastest search for windows 7 there is on the planet, but i didn't realize the thread had a green check mark, so posted it again in the general section,,, well someone deleted it from there, i wasn't trying to cross-post just made a mistake, btw name of the file is searcheverything all one word,,thank you again,, awesome site glad to be a part of it.
Drew
28 Sep 2009   #4
SquonkSC
Win7 Build 7600 x86
Drew
Well, glad you got it fixed so cheap.
About non signed drivers.
Generally I would say you're right, but for some small programmer's like the one from "virtual audio cable", getting the drivers signed is just too expensive. (100's if not 1000's of $)
If you look at the guys site you can see it is an enthusiast at work without commercial motivation.
You can generally trust those. But it's a personal choice.
Your fix is easier and more practical.
Just be careful you don't blow up your mic port with the output signal.
greetz
 Sound problem
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Sound problem perrsists even after new sound card
As some of you might remember, a few weeks ago I had a problem with sound after I built a new PC and kept my old Win 7 installation using sysprep: https://www.sevenforums.com/sound-audio/280175-onboard-sound-issue-new-pc-build-2.html#post2308990. The problem was that the volume levels were off, and...
Sound Problem
I have tried to play mpegs and Avi files on Nero Showtime (Nero 7 ) and also on Divx 8, Realplayer and Quicktime but I get no sound. I do get sound on Win Media Player only. I installed Klite codec pack for Win 7 64bit. Do I have to install the 32bit codec pack for the 32bit programs to...
Sound problem - need to 'scan for hardware changes' to get sound
Hi everybody I have a fairly strange problem with my Laptop. It came originally with Vista and a while ago I updated to Windows 7 32bit Home Premium. Since then I don't have any sound after booting the Laptop. By chance I found out that when I go into the device manager, right click on the sound...
Hardware & Devices
Windows Media Player Problem - Sound/skipping problem.
Oh look, another windows media player problem, lol. Well, it's something really weird, at first i thought it was just my computer being all slow or the file was messed up, No matter what movie or format i play it makes this weird screeching noise. It also lags pretty bad. I tried the scans, i did...
Music, Pictures & Video
