Headphone audio problems.
  1. Posts : 1
    Windows 7 Home Premium 64bit.
    After powering on my PC today, I noticed a light high pitched ringing noise coming out of the left side of the headphones. I then tried to play some music, and had very low levels of sound coming out of the left side, while the right seemed seemed to be working fine. Does anyone have a general idea on what could be wrong?
  2. Posts : 21,004
    Hello and welcome Ette just what do you have set up for audio - onboard / sound card adaptor etc?
    Mate some specs on the system is always helpful tracking down faults.:)
  3. Posts : 2,240
    Windows 7 Ultimate 64 bit
    something simple to check....are the headphones fully seated in the 3.5mm jack, assuming that the head phone use 3.5mm inputs. Sometimes if the jack is not fully pushed in all the way you get what you're experiencing.
  4. Posts : 21,004
    Yes Bass maybe it could just be faulty or dirty contacts some of those internal sockets are pretty flimsy eh?
