How to Get Dolby Digital Plus Sound on Older Computer?
  1. Posts : 131
    Hi All,
    I have an older computer that I'd like to give my nephew. However, I noticed there is no audio/sound when playing the newer DVDs (Dolby Digital Plus).
    Dell 5150, Pentium D820 Dual Core 2.8 GHz, 250GB, SII Hard Drive (7200 rpm), 3 GB Memory, DDR2 SD RM, 533 MHz, nVidia Graphics 6800. I'm currently running Windows 7 Home Premium 32-bit on this computer.
    The upgraded sound card was not compatible with Windows 7 so it had to be removed. Currently running on just the on board sound.
    Do I need to upgrade the sound card in order for him to play Dolby Digital Plus?
    Thanks, ms:)
  2. Posts : 592
    WIN7 Ultimate 64bit
    No budget mentioned!
    Try this
    ASUS - Multimedia- ASUS Xonar D1
    There is also a Pci-e version
  3. Posts : 131
    Hi Neo,
    I'm so sorry for not responding sooner. I was hooking up the new computer.
    Thanks so much for your advice, ms
  4. Posts : 592
    WIN7 Ultimate 64bit
    You're welcome.
  5. Posts : 131
    Hi Neo,
    Interesting that you picked an Asus sound card. My new computer is an Asus:
    Asus CM-6870-CA-3AA
    Processor Type Intel Core i7-3770
    Processor Speed 3.4 GHz
    Processor Cores 4 with RAM 16 GB
    Hard Drive Capacity 2 TB
    Hard Drive Speed (Revolutions Per Minute) 7200 RPM
    Optical Drive 12 x Blu-Ray Combo
    Graphics Card nVidia GT630 - Graphics Video Memory 2 GB
    Display Monitor - VE248Q (separate)
    Audio Sound Card ALC892 - Audio Output High Definition Audio
    Power Supply 300 W
    I feel like I'm driving a sports car with this new system.
    Cheers, ms
  6. Posts : 592
    WIN7 Ultimate 64bit
    Speedy (Power supply looks very inadequate - but what do I know)
    - if you try the Novabench for a bit of fun you should be around 1300-1400 at a guess
    I just upgraded this year too (from 2x 9yr old Agp/Barton 3000's)
    They still did everything I needed for everyday tasks/played Crysis easily but HD/Blu-ray was just too much. Even managed to sell them!
    Had to build reasonably powerful new pc to cope with editing brothers wedding which I shot in HD video.
    Bought a second-hand/3 month old Amd 8150 Bulldozer cheap/16gb ram (it keeps up with intel top i7 processor when doing video compression/conversion - the only area)
    Novabench 1320
    Just finished a low power, uber quiet, HTPC with AMD A10 5700 /16gb ram
    Novabench 813
    I have one of these Asus D1 Soundcards around 1 yr old - now sitting in a box
    (my latest motherboard Asus F2A85M-Pro doesn't even have a pci slot!)
