No Audio Windows 7 64 bit Problem
  1. Posts : 1
    Windows 7 64bit Professional
    I've been trying for weeks to fix my "No Audio device" problem on my Windows 7 64 bit computer. At first I didn't have internet so I assumed it may have been missing drivers. But I have had internet for a while now and tried updating the necessary drivers and it still wont work. I have checked to see if maybe my speakers were the problem or maybe the audio port on my motherboard. Neither were the issue. I had this same problem once before but it sort of fixed it self, we were unsure then about the cause or the solution. Now it's not only my computer but my boyfriends as well. I've tried different drivers and other solutions posted on the internet with no luck. I've also tried troubleshooting the problem but my computer says that all audio devices are working, but it's also saying that no audio devices are detected. My father works with computers for a living and he's also curious about the problem, he's tried his best to fix it as well. If anyone else has experienced this problem and has a working solution, please help me. Thank you.
  2. Posts : 53,365
    Windows 10 Home x64
    Welcome to Seven Forums xBlankx. It will be best if you fill in your system specs
    System Info - See Your System Specs
    Also, let us know what you do that creates the error, and the exact error. Screenshots are best
    A Guy
  3. Posts : 54
    32bit Windows 7 Ultimate
    Who knows, but found this link if it helps?
    No audio devices are installed
    Regards
