Onboard audio and how to get 5.1/7.1 sound via HDMI
  1. Posts : 501
    Windows 7 Ultimate X64
    I'd figure I've got some time to make a new thread here for members of SevenForums who may have experienced some difficulty getting sound out of their computer via HDMI
    Locate the SPDIF connector on your motherboard using a 2 pin spdif cable
    PIN assignment #
    1 Power
    2 No pin
    3 SPDIF
    4 Spdifi
    5 GROUND
    6 Ground
    Notice the bold and RED (SPDIF) and BLACK (ground)
    Here is my motherboard EVGA 790i Ultra as an example marked by a red square (see attached pic).
    Connect the 2 pin SPDIF cable from your motherboard (output) to your video card (GPU) input.
    If you are running SLi(multiple video cards) pick the first video card (PCI-E slot #1).
    NVIDIA based cards only (GeForce 8 series and up) may work for you.
    Connect the graphics spdif pass through to your motherboard and then audio will "pass through" over to the hdmi.
    If you're not sure look between the SLI Link and the 6 pin power connectors.
    NOTE: make sure you are doing this with the computer power OFF, disconnect the power cord, as I am not responsible for any electrical shocks that may arise.
    Make sure your speakers are connected properly on your AMP, and you may need to configure your AMP settings (HDMI settings).
    Go to Control Panel>Hardware and Sound>Sound and configure your audio settings.
    Choose the correct sound output, you will see SPDIF out, and HDMI out.
    NOTE: you may need to boot into your BIOS and enable HD Audio to ENABLED or ON (should be on by default).
    Once all is done, now you have audio via HDMI (DVI-D adapter may be required).
    I will do a future update how to output sound from soundcard via HDMI if anyone needs that info, I would be more than happy to help out.
    Enjoy:)
    Attached Thumbnails Attached Thumbnails Onboard audio and how to get 5.1/7.1 sound via HDMI-spdif-info.jpg
  2. Posts : 6,879
    Win 7 Ultimate x64
    You should mention that this only applies to Nvidia cards (8800 series and up), as the ATI HD series of cards all come with the Realtek HD audio built into the card.
    Also for a selection of Nvidia cards and what to look for on the card, as well as hot to quickly and cheaply (free actually) make the cable if one didn't come with the video card,
    Guide: 8800GT/9800GT/9800GTX Sound over HDMI (Now including Creative cards) - Overclock.net - Overclocking.net
  3. Posts : 803
    Windows 7 Professional x64
    I have audio trough my ATI HDMI card, but I did not know it is Realtek HD audio. Device manager says just ATI HD audio device.
  4. Posts : 6,879
    Win 7 Ultimate x64
    Not sure as i haven't done it, but I think that changes if you install the Realtek HD drivers which also have support in them for the ATI version. I do know that (from reading elsewhere) that if you install the Realtek driver, you will then get the Realtek control panel.
  5. Posts : 1
    windows
    happy here
    tank you i can understand your problem i can solve if you want know that..plz visit here...cick here
  6. Posts : 4,280
    Thanks for the link stormy13
