Sound card drivers problem???
Page 1 of 3 123 LastLast
  1. Posts : 13
    Windows 7 Ultimate 64bit.
    Hi everyone... I need urgent help..
    My volume icon keeps saying no speakers or headphones are plugged in, I can not get any sound from my laptop. When i click volume icon / sounds nothing is there in playback except Digital Audio HDMI which is
    '' Not Pluged In ''
    Things i have already done...
    1.. Tried system restore, unfortunately my laptop had no store point.
    2.. I cannot find any audio enabled option in bios setup .
    3.. I download all these latest drivers but still no luck
    https://support.acer.com/us/en/produ...x?modelId=4281
    4.. I tried to do manually install the above mentioned audio driver through Device Manager / Action / Add legacy hardware but ( i only get '' realtek HD audio '' with yellow exclamation mark code 10 Error)
    in device properties
    5.. Windows update & troubleshooting also give me no luck
    6.. I already done clean installation of Windows 7 x64 several times but failed
    7.. dxdiag detect no sound card
    8.. Now i only have High Definition Audio whereby it states that device is working properly. But my
    sound card is not supporting it.
    NOW PLZ HELP ME WHAT I AM MISSING OR MY SOUND CARD IS DEAD
  2. Posts : 2,014
    Windows 7 Professional 64bit
    Hi intel and welcome,
    Please upload your msinfo32.nfo file so we can help further.
    To get this: Start Menu>Type msinfo32 into the Search programs and files box.
    When it opens, go to File, Save>Save as msinfo32.nfo and save in a place you will remember.
    Let it finish the process of gathering and saving the system info>Right click the .nfo file.
    click send to compressed (zipped) folder>Upload the .zip file here.
    Cheers
    Dave
  3. Posts : 13
    Thanks for the respose. Here is the file I have attached the said file in RAR.
    Please do help me as I have tried all i could ... Googled up everything went on forums etc but nothing seems to work not even a single thing really... No fix for me.
    My laptop came with win7 home I upgraded it to ultimate and sound was ok until one fine morning without doing anyhting the sound wouldn't work. The last thing i tried was to connect my laptop to our office projector through HDMI but the projector did not have HDMI but a video input port so we got the HDMi-VIDEO cable after that nothing happened wrong and I used my laptop then the next day when I started it the sound was gone. I have been trying everything for the past week or so but nothing helps. i am really frustrated.
    Reinstalled windows.. went back to home then again to ultimate x64 but no use.
    Tried latest drivers but nothing on acer site I have the latest ones the worked fine before..
    System restore..nothing.
    In the device manager it says intel display audio if i uninstall it then it installs through windows and says high definition audio but wont take my realtek.. someone said new video adaptor disables onboard audio and I can change in CEMOS setup I think its called BIOS... but my bios doesnt have an option to enable/disable onboard sound etc just has the graphics one as my laptop has built in video plus nvidia 3d graphics card....
    i would love to have this issue resolved.
    Seems like HDMI sound or audio thing is blocking realtek from installing or something like that.
    Sound card drivers problem??? Attached Files
  4. Posts : 13
    Another thing worth noting maybe.
    the file I attached above was without installing my realtek drivers. The realtek wont install right. So the generic HD audio was installed by windows itself and i uploaded that file. However, I did another thing I went ot device manager and disabled high definition audio controller in system devices and then I could force my realtek driver to be installed. Then after doing that now my sound,game controller is showing realtek high definition audio all right but it has a yellow exclamation mark with error message device cannot start code 10. Similarly, when i did that and opened the msinfo32 I saw a change...
    In the first file I attached with generic resources it said ok in everything but not in this attached new file named ok2 here I have done it after getting realtek drivers on as stated above. This time this file shows error in status in sound device under components... please see the file attached.
    I think Dave you might be on to something and would be able to resolve this please...???
  5. Posts : 2,240
    Windows 7 Ultimate 64 bit
    Can you post a screen shot of you device manager window and your playback device window? Are you sure you are installing the right bit type sound driver?
  6. Posts : 2,014
    Hi Intel,
    Thanks for the info.
    Your problem lies here (as you already know):
    Realtek High Definition Audio ROOT\MEDIA\0000 This device cannot start.
    While i look through the msinfo32.nfo please update to:
    Windows 7 Service Pack 1, you should be able to do this using Windows update. This will help stabilise your system and maybe the root of your issue.
    Once done, uninstall all realtek drivers, reboot, and it will probably install windows generic drivers.
    Re-install correct driver from Acer site.
    See if that sorts your issue and post back status,
    Cheers
    Dave
  7. Posts : 13
    Bassfisher: here are the screen snapshots you asked for...
    I have taken the snapshot of my playback device window (shows only hdmi and that is with the red sign too cuz it isnt plugged in) however doesnt show speaker or microphone here). Also a snapshot of device manager with yellow exclamation on realtek and not on generic windows ones... and also once you take right click properties of the realtek sound drivers its mentioned device cannot start code 10.
    What can you suggest...???
  8. Posts : 13
    Northernsoul55 said:
    Hi Intel,
    Cheers
    Dave
    OK Dave i shall try to get on to windows 7 sp1. then I shall uninstall all drivers software for the sound device and then reinstall again... I shall fresh download the drivers for sound from acer support site and do that... Lets see what happens. In the meantime if you come up with something else, do let me know ...
    I hope we can get this resolved.
  9. Posts : 2,014
    Hi Intel,
    Cheers
    Dave
    If you have any problems with windows update try the stand alone Win 7 SP1
    Download Windows 7 and Windows Server 2008 R2 Service Pack 1 (KB976932) from Official Microsoft Download Center
    The one you want is: windows6.1-KB976932-X64.exe 903.2Mb
    Cheers
    Dave
  10. Posts : 13
    [/QUOTE]
    Cheers
    Dave[/QUOTE]
    Dear Dave, I did not have any problems with the windows update feature. It downloaded and installed sp1 with the same code you mentioned i.e. KB976932-X64 and restarted took its time and then upon restarting stated win7 sp1 is now installed... However, I doubt if it was 903 MB... anyway, I am now downloading fresh drivers from acer support site for the sound... Its the same driver set that I have but was thinking that maybe the one I had saved on hard drive earlier on might have got curropt.... Not that there are many chances of having that happen but then i am in Pakistan and curroption here is in abundance
    Once I download fresh drivers I will have them installed and see what they do. By the way, how to I uninstall previous ones so all their entries are removed completely and absolutely.... will uninstall them from device manager and then remove program in control panel... would that be enough ???
