Audigy Soundblaster 2 Mic issues
  1. Posts : 29
    Windows 7 64 Bit
    Driver version SBAX_PCDRV_LB_2_18_0017
    Anyone found a fix for the mic issues with this?
    SBAX_PCDRV_LB_2_18_0017 Windows Driver « No More Goat Soup
    "Vista / Windows 7 microphone issues still remain (undocumended by Creative Labs, typical – *Goat)"
    The mic is Line-In 2.
    Uninstalled and re-installed driver.
    When I first install the driver the mic works, but I get feedback through the speakers, if I try to change the settings in the recording device panel, Line-In 2 becomes unavailable.
    Thanks.
  2. Posts : 6,879
    Win 7 Ultimate x64
    You need to mute the mic under playback, not in recording.
    Also are you connecting the mic to the line-in jack or the mic jack?
  3. Posts : 29
    Windows 7 64 Bit
    Line in 1/Mic in
    There is no playback mic shown to mute, in the recording tab all line/mic inputs are showing as "Currently unavailable" even though the device(s) are enabled.
    The mic worked (but with feedback to the speakers) after a reinstall of the driver, but as soon as I tried to change the settings for it, the above happens.
    Audio playback works perfectly well, its the input side that I`m having problems with.
    All the hardware worked perfectly with Windows Xp, so, I think this could be a Windows 7 driver issue.
    I`ve found an alternative driver here
    Official kX Project Site -- News
    I`ll try that as a last resort.
  4. Posts : 6,879
    Win 7 Ultimate x64
    Might be better giving this a try,
    SB Audigy Series Support Pack 4.5 (10/29/2012)
    Look for the line-in/mic in the Windows Playback properties, not the Creative control panel.
  5. Posts : 29
    Windows 7 64 Bit
    Thanks, I`ll give that a try.
