no sound need help
  1. Posts : 4
    windows 7
    no sound need help
    I just had my computer reformatted and when setting it up i could not get the sound to work i have been troubleshooting this problem for two days with no luck. I have install drivers and then uninstalled them and tried different drivers. I took screen shots of any thing that i thould would be usefull. My speakers work because i hoooked them up to other devices and they work fine and the green bar is jumping in when the sound mixer is up and there is music playing in windows media player. I have a onboard sound card with three ports green orange and blue which i have tried all of them. any suggestions would be helpfull i have run out of ideas thanks.
    Attached Thumbnails Attached Thumbnails no sound need help-0.png   no sound need help-1.png   no sound need help-2.png   no sound need help-3.png   no sound need help-4.png
    no sound need help-5.png   no sound need help-6.png   no sound need help-7.png   no sound need help-8.png   no sound need help-9.png
  2. Posts : 2,606
    Windows 7 Pro X64 SP1
    Can you provide a full model number for the PC or motherboard?
    That could be helpful.
  3. Posts : 21,004
    Hello and welcome stephen Yes mate as Bob says some specs would be good but fro the record the green socket is your out for the speakers.
    You mention onboard sound card I take it you mean the mobo audio or a plug in card?
  4. Posts : 4
    windows 7
    Motherboard: ASUS P5S800-VM
    here is the audio ports
    I have my speaker which are altec lansing series 100 plugged into the green port
  5. Posts : 2,606
    The P5S800-VM has a Realtek ALC655 sound chip, according to Asus:
    ASUS - - ASUS P5S800-VM
    Have you tried the drivers direct from Realtek?
    Realtek
    These drivers include support for the ALC655.
    I don't see any additional SiS chipset drivers that might be wanted.
    (That's an old board. SiS chipset, AGP graphics slot, etc. Initial BIOS release from 9/2004. Most recent BIOS 7/2007.)
  6. Posts : 4
    windows 7
    i tried that divers but no luck
  7. Posts : 25,847
    Once again updating your specs would help the good folks here help you.
    This should help.
    System Info - See Your System Specs
  8. Posts : 21,004
    Stephen the specs as Layback says mate but just an alternative for you have you thought about a sound card for the machine?
    It would save an awful lot of grief trying to work out the on board stuff and they are not expensive.
    I have Asus Xonar DG cards in my machine and the GUI for mixing and adjusting the sound to your own tastes is just fantastic. Mine are hooked up to 5:1 Logitec Z506 systems the cards were about $35 and fitting is a piece of cake. Sound well is my cup of tea and I am a bit fussy when it comes to audio.
    But the choice is yours of course
    ASUS - Multimedia- ASUS Xonar DG
  9. Posts : 4
    windows 7
    heres the scan results
