Sound card advice
  1. Posts : 5
    Windows 7 64 bit
    Sound card advice
    Hi, i have the Logitech Speaker System Z313 (was sent as replacement for my old one) but it does not have Bass controls on it, so i was wondering if i got a sound card could i control the bass through that ?
    Also
    If i got a sound card is there anyway i can control voices in movies ? i tend to watch a lot of movies late at night, and am having to constantly turn the volume up and down
    Thanks.
  2. Posts : 2,606
    Windows 7 Pro X64 SP1
    What are you using for sound now? Good onboard sound (Realtek) has some of the features of a discrete sound card.
    I recently got a Sound Blaster Z card. I believe that it has the features that you're asking about. I haven't exercised them yet, because I live alone in a "single family" house. There's no need for me to limit the volume at night. I mostly watch movies on an LCD TV, anyway.
    The Z may be a bit expensive for your needs. Amazon UK has it for around £80.
  3. Posts : 21,004
    Personally I put the Asus Xonar DG in my machines mate not expensive and you have a really nice GUI to play around with the sounds.
    Plus you can use 2:1 up to 7:1 systems with it move the speakers around etc etc :)
    ASUS - Xonar DG
  4. Posts : 76
    Windows 8.1 Pro
    ASUS DG to begin with DX for bet bang for buck in the entire world. For the feature you want i'm sure there must be some softwares which can do that. My DX can control bass but not automatic volume control.
  5. Posts : 21,004
    Absolutely Rockfella I think that one is brilliant but for what I wanted and at the price the DG is just fine.
    I can control all frequencies and the effects that I want but what I don't get is why would you want automatic volume control?? I have that in my Mazda's Bose system and can see the point but in a computer I am a bit perplexed.
  6. Posts : 5
    Windows 7 64 bit
    cheers for the info guys, will look this card up
